IBM Selectric II correcting won't power up
Typewriter has been stored some 25 years .... It powered up briefly and seemed to type ok. I shut it down, but now it won't power up ..... don't know how to remove the cover to get at the switch....assuming it is the switch....HELP
Bill
  • 3,594 Answers
Open the upper cover, remove the platen (roller) there is a latct on each side that has to be pressed down, after the platen is out thetre are two latches one on each dide just inside the the sides of the case pull them to the front, flip the margins inside and lift the case, give the motor a little push, if it starts get a can of WD40 and spray everything inside the T/W that moves.
DickyO
Posted on Oct 24, 2008
77dodge is only starting when my foot is all the way down on gas once I let go it turns off don't know why opened the choke it ribbed up but soon as let go of gas off
Engine runs for a short while then quits. - CarGurus
www.cargurus.com > Questions > Dodge > Power Wagon
CarGurusOct 28, 2013 - It starts right up and runs slow or fast for a short whil... ... Ok, when it dies look down the carb air horn and work the throttle ... of my toys for 40 years .. quite frankly I just don't know what six way power seats have to do with this guy's problem ?.... my 77 dodge doesnt have spark all new cap rotor plugs wires ...
All comments on Fixing A Car That Cranks But Doesn't Start ...
https://www.youtube.com/all_comments?v=064Ilsz8Fzg
my Chevy van does this I replaced the fuel pump but it still cranks and won't start.. Read more .... She went into a store and came out to a car that only cranks, but nostart.I sprayed starting .... Fresh gas and gas all the way up to the fuel rail. ..... A few hours later I was able to start the van again but then it shut itself down.
Engine won't start - almost no fuel to carburetor - Classic ...
www.classicwinnebagos.com > ... > Tech Talk > Chassis > Chevy (GMC
Feb 25, 2013 - 25 posts - ‎13 authors
Amazing with little starting fluid the engine wants to run, but nothing else. .... If that's the case, is my only solution is to open-up the carb and clean, ... You need to take the tank down too, to make sure it doesn't have a lot of junk in it. .... it shot a stream of gas all the way to the radiator support, about 26"... it's ...
Intro for a New RV and Newer Owner
Nov 4, 2012
Chrysler Electronic Ignition System
Aug 13, 2009
More results from www.classicwinnebagos.com
Worst Stuck Story? [Archive] - PlowSite.com™ -
Jan 03, 2016 | Cars & Trucks
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
Anyone got a possible answer for why my IBM correcting Selectric II won't come on?
If you know how to remove the upper cover there are a few things you can check. turn it on if the motor is trying to turn it may be gummy motor bearings lube them If it dosen't try the off on switch may be gummy. almost anything you will need a tech.
DickyO
Oct 08, 2014 | IBM Correcting Selectric II
Recommendation for IBM Repair Company
I Googled Typewriter repair Washington DC and got 4. I have no idea what they charge.
DickyO
Apr 02, 2014 | IBM Correcting Selectric II
Lost power to the typewriter
The on off switches are filled with grease, after years these get gummed up, must be dissasembled to be fixed, or another on off swtitch.
You tube will show you how to replace or repair switch.
May 05, 2017 | IBM Correcting Selectric Ii Typewriter
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Xl1500 won't type lock light flashes
Try poping off the shift and shift lock key tops to see if the springsb are damaged or sticking down.
DickyO
Aug 01, 2012 | Smith Corona Typewriter XL1500 Refurbished...
Selectric II Pitch-shift lever won't change from 12 tom 10
If you haven't changed the pitch for a long time the lubricants dry up, if you have some WD40 spray it in the slot inthe margin bar where the L. & R. margin levers ride. Give it a few minites to work.
DickyO
May 16, 2012 | IBM Correcting Selectric II
Shut off won't turn back on
how long have you waited since it shut off? it may be overheating. if you've waited for a while and it still won't power up, you may need to test the power supply. if you don't have a power supply tester and most people don't you can remove it from the case and take it to any pc shop. they may charge you a couple bucks but most shops won't do that. if it's bad it will need replaced obviously, if it's not let us know :)
May 06, 2012 | Dell Vostro 320 Desktop Computer
1,848 people viewed this question
jasbo
jasbo
