Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Which number is colder-2 or 9
Are the lower numbers colder or warmer on the manual thermostat inside the fridge?
ICE MAKER CYCLES OK BUT DOES NOT FREEZE COMPLETLEY
Posted on Oct 08, 2008
  • 943 Answers
Hi. thanks for the question. #2 is warmest ,gets colder as numbers go up. thanks the appliance doc
Posted on Oct 01, 2008
How can I turn up the fridge settings. It's not cold enough
you need to turn down the settings of a fridge --the lower the number on the control knob the colder the fridge
it is the freezer that the system is reversed where the lower the number the warmer the freezer
Sep 06, 2016 | Refrigerators
What setting must my fridge and freezer be at. Thanks
RFA70 settings Controlling the Temperature of the Fridge Compartment The left hand control wheel on the front panel adjusts the internal fridge compartment temperature. The internal temperature should be 5?C or colder, although some sections such as the salad bin will be slightly warmer. The setting of the control wheel will depend on the location of the fridge freezer, the room temperature and how often the door is opened. The normal set point (marked by a 3 on the dial) is usually suitable. If you need to adjust the temperature turn the control wheel using a coin to avoid damage: Clockwise (higher number) - Colder Anti-clockwise (lower number) - Warmer
Here is a user manual go to page 6 http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Fridges/HBRFA60.pdf
APPLIANCE 911
Sep 04, 2016 | Refrigerators
When turning up or down does that number mean the current room temperature or what you want it to be? And when doing that is the lower number mean cooler or warmer? And the number being displayed at all...
The number you can adjust is the temperature you want. A lower number is colder and a warmer number is hotter. Remember that even if you turn it up or down by a lot, it doesn't change the temperature any faster. The number you cannot adjust is the temperature at the thermostat.
Oct 17, 2017 | Heating & Cooling
Temperature control are the lower numbers colderr or warmer?
Hi there, the higher the number the colder the fridge, unless the numbers are in degrees. If it's numbered 1-6, 6 is the coldest. -Alex
Aug 17, 2011 | Belling 3 cu. ft. / 85 liter Upright...
The number on the dials..is the lower number for cooler and the higher number for a warmer..Everything is freezing in my "small-dorm size refrigerator"
The lower number is for warmer, higher number colder, unless indicated otherwise. May need a thermostat. Whats the model of your refrigerator?
Feb 23, 2011 | Magic Chef Refrigerators
Is it right what they say " The higher your number on the tempreture gauge the warmer it will be inside the Fridge/Freezer
#1 is warmest #2 is cooler#3 is colder etc.....fridge should be between +2C to +5C and a freezer -18C or lower(-20)
Sep 17, 2010 | Refrigerators
What is the lowest setting on the temp on a Hotpoint Ctf18ga
Hello Dustin,
Typically the lower the Letter or Number is the warmer setting for the freezer or fridge section. If you want to make them colder, move the control setting ONE (1) increment at a time, in any 24 hour time period (up or down) and allow the fridge to adjust before making another change in the settings.
Again, A is warmer than B, and 1 is warmer than 2, and so on. So going to a higher letter or number, will make the unit colder.
Just remember it will take at least 24 hours for your unit to adjust and compensate for the changes, so only make them gradually, so you can tell if you've reached the desired cooling settings for both the fridge and the freezer. Typically, most manufacturers recommend that the starting position be in the middle of the dial and that you adjust them up or down from there.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Refrigerators
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Apr 19, 2007 | Magic Chef MCBR170 Compact Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
202 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
