Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
F5 code on a kenmore range
On a Kenmore mod#911.7398811 I get an error code of f5 when I turn on the oven to bake. Could this be the ignitor?
  • 172 Answers
Hi mrscottd,
The f5 indicates a loss of the relay drive circuit. To correct you can turn the power off to the range at the breaker box and wait about 10 minutes, then turn back on. This will reset the board. If the error returns you will need to replace the electronic range control (ERC). The part number for the control is # 338692 price $338.49 at Sears or My price $299.99 delivered. Good luck to you and please dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 30, 2008
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
1. Sears Kenmore Gas Range 2. Model No: 362.75481890 The oven will not ignite. The igniter-oven burner will glow but the gas will never start to flow. This has gradually occurred and has now come to...
Hello Everett,
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when set to bake ignitor by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than that replace bake ignitor. If you dont have amp meter take my word for it since in my 30 years appliance repair career i have when the ignitor comes on, that it's weak, to be the problem 100% of the time
Jul 31, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My 2001 Kenmore oven error says ``E1 -F5-`` What does that mean
The E1- F5 error is a door lock error. The control has likely failed. Sometimes when you disconnect power to a range and reconnect it the electronic range control gets messed up.
You should disconnect power for 15 seconds and reconnect and see if that helps.
If it doesn't fix the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.Then turn off power again for 15 seconds and back on. Sometimes these work, but if the control has failed it won't make any difference.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Kenmore Ovens
Kenmore oven code f5 can't get door to open
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2010 | Kenmore 9535 Electric Range
My kenmore oven 911.30465 is giving error code F5. What does this mean?
Jul 22, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Trying to self clean my kenmore electric oven get error msg e1 f5
Oct 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Have a Kenmore Elite oven. When I try to turn on any of the heating elements, I receive an F5 error. Any suggestions? Thanks much.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
Kenmore oven locked after celf cleaning
Aug 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
1,896 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
