Question about HP Compaq Evo Notebook N600c
Charging problem My sons laptop runs great when its plugged in. It needed a new battery so I bought one,when put the battery in to charge it up, the machine shuts off completly. Any clues??
    Novelist:
  • 169 Answers
Sounds like a defective battery to me ...or perhaps a faulty charging system. Least expensive solution is run on no battery, AC only. Second cheapest is replace the battery. Third option (note I didn't mention "cheap") is to replace the motherboard. Last option is to replace the laptop (might be cheaper than fixing the laptop, if you factor in age, warranty, time, effort and headache involved.
Hope this helps - remember to rate :)
Posted on Oct 02, 2008
My ASUS K52 battery is at 58% and not charging why ?
Is this an ASUS charger and battery? Some ASUS laptops will not charge after a certain charge is reached, but it's usually in the 95-100% range to prevent overcharging.
If you bought an aftermarket charger, it may very well not have the amperage to charge while running the laptop.
Feb 13, 2015 | ASUS 156 K52 Notebook (AAC4001K52DRA1)
Batteries wont charge
You would need a voltmeter to check the charger in order to see if it is charging the batteries. New batteries if purchased from a reputable outfit will have a nominal charge and should work initially in order to test the scooter. Depending on the model check for blown fuses and disconnected wires on the battery boxes, connections, plugs and charging circuits including the wall outlet. The display on the scooter will indicate the state of charge and the key switch should work and give an initial indication that the scooter is on. If you provide make and model I can respond with more specific information.
Mar 23, 2014 | Health & Beauty
HP Mini 2140 "Plugged in, charging" but not charging
Hello jorel, most likely its a failure of the system board particularly the charging section, a broken pin or a loose terminal. work will be internal, suggest you do away with the battery. its better to operate it at home, or bring the charger with you. Maybe its time to get a new one.
Dec 05, 2013 | HP 417035-001 - HP Pavilion dv2000 Series...
I bought a brand new 170.00 battery for my Dell studio 1737 laptop. It continues to say plugged in, not charging. What can i do? I've tried plugging in and replugging in the charger.
For a new battery, we advise that you update the BIOS of your laptop, and open the hardware automatic identification port of your laptop.
When you use it firstly, you need to discharge till 5%, then charge it about 11 hours. Usually, new battery need to fully discharge and charge for three or four times, which can achieve the best performance.
About the new battery, please set the power management of your laptop: Property -> Screen Saver -> power -> Power scheme -> Portable / Laptop -> please cancel about low battery alarm and serious shortage of battery alarm when use the battery.
For some laptops, you could try to close your power management tool to test your new battery.
You could try to take out the battery from your laptop, and put it back again, repeat several times. Make sure that it isn't a poor contact problem between the battery and your laptop.
If the battery works in higher temperature, the battery protection plate will work and the laptop restart program will make a termination order. You can take out the battery, put it back again, and avoid work in high temperature.
In order to avoid some damage to the battery, please note:
Please don't take out the battery when the laptop is in run status.
Please don't pull out the ac adapter frequently when the battery is charging.
Please use high quality and reliable laptop charger, not to use the universal laptop charger.
Are there something wrong with the new battery can not charging?
That's not usually the case. When equipment for the first time to recharge the battery, the instability of the voltage and current may cause the battery charge to 50% (sometimes more, sometimes less), and equipment stop charging the battery.
If this happens,don't worry. You just remove the battey from the equipment, recharge again. First charging a new battery may need several repeated process. Please be assured that this is normal.
Or you can visit http://www.batteriescenter.com.au/.
Jun 19, 2011 | Dell Studio 1737 (Studio 1737-RubyR) PC...
When I plug in the adapter the blue light on the charger goes out immediately and does not charge the battery. I bought a new charger and it does the same thing. I've had both chargers checked and they are...
I got a brand new 170 battery for my studio 1737 . Now the battery has charged, but I plug it in and the window says battery plugged in, but not charging
May 14, 2010 | Dell Studio 1737 Laptop
Dell inspirion 1501 laptop, not charging battery light showing red, have bought a new mains adaptor but still not charging
Does the back dc jack seem loose when you have the ac adapter plugged into it? Wiggle the cord right where it plugs into the laptop. If it moves around then most likely the dc jack on the inside has one of it's 3 points of contact broken. This means that someone would need to re-solder that contact or put a whole new jack into the laptop. Another thing to try is replacing the battery. Sometimes they won't charge because they are bad. Another thing to try is take the battery out, plug it into the adapter, turn it on, get into windows, shut down, put battery back in, turn on. See if that resets the battery and makes it charge.
Apr 30, 2010 | Dell Computers & Internet
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
1050 EB-1 not charging batteries.
Give Fremontek a call (I have no affiliation with them)
They know Averatec's better than anyone else I know, and can frequently diagnose via phone.
My bet is that youmight be able to "reset" or may need a power management board.
[url=http://www.fremontek.com/]FREMONTEK[/url]
Dec 21, 2009 | Averatec 1000 Notebook
Hello, SONy Pcg-FRV37,Power problems
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings.
Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
Oct 16, 2009 | Sony VAIO FRV37 Notebook
HP Compaq Evo Notebook N600c Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
