Question about Kenmore Vacuums
Won't start Was working. Then stopped. Changed outlets, Changed the bag. Didn't help. Suggestions? It is about 7 years old.
    Scholar:
  • 157 Answers
Hello rperlin. Your AC cord most likely has a broken wire in it. Please be careful is this action I suggest and DON'T touch a bare wire. Plug unit in, turn power on, now sowly flex the AC cord close to the plug, no sparks or motor starts, flex the cord near the vacuum, ext. If you get an action you have found the location of your broken wire. Replacing it will be a chore. Make notes on wire color and witch one went where. A factory replacement may be costly, Visit your local hardware store & ask for help in electrical dept. Electrical lesson#2. Aquire a DVM or more commonly VOM(meter) & check for ohms in the AC cord. IF you elminate the cord HOUSTON WE HAVE A PROBLEM. Your switch, motor brushes, or control switches internal are the problem. Good luck.
Posted on Oct 01, 2008
Easy Flo SQ9020 stopped working - what should I check to identify what the problem is?
I am assuming you have checked the breaker that it is on? Have you tried using it at a different outlet?
Jan 10, 2015 | Easy Flo Vacuums
Bag needed changing there was no burn ing smell or strange noises before i changed bag after bag was changed it wouldnt start. the cord is new no fraying and vac is about 5 years old. didn
I'm not real experienced with this model vac, but I do know that many of the newer vac's are being manufactured with a small button or lever, whatever the particular brand of vac decides would best fit on their unit, that would be located somewhere around the edge of the bag door opening and would need to be depressed by having a bag inside in order for the machine to run. I would check for something of this nature to be sure that during the bag change that you didn't just miss putting it in quite right to depress the go button. Other than that, it's entirely possible that the switch died. If that's the case you'll need to bring it in to a vac repair shop for help.
Nov 11, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Changed bag now motor won't start. The beater still works
you may have debris in the area around the motor, or it may have something lodged in the motor.
Nov 20, 2011 | Vacuums
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Oreck XL2 Ultra
I have the same problem and mine is less then a year old.
Aug 21, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Hello, My Electrolux Renaissance is about 12 years old. It worked great for years, but now it keeps turning itself off...about every 15 seconds or so. The bag was just changed recently, too. Is there...
Odds are you have an obstruction somewhere. Check all of the hoses and the power head to ensure that there is nothing blocking your airflow.
Also note that if it keeps popping the front bag door open, that's usually indicative of either the bag being full or not being installed properly, which can give you the same results, so try taking the bag out and popping it back in just to make sure everything is aligned correctly.
-R
Jul 31, 2008 | Electrolux Vacuums
Won't work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12151&thid=646957
Won't work (by 2 users)
Posted by AndiR on Jun 04, 2008
My Eureka Mighty Mite 3670 Bagged, was working fine, and we unplugged it to switch to another outlet in another room and it just stopped. We tried several other outlets and it just won't turn on. We thought maybe it got hot because we had been using it for a while and we let it rest for a while and then changed the bag just to be sure, although it was not full. But it still will not turn on. Any ideas……X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by Guest, posted on Jun 06, 2008 I had the same problem today. Have a 9 amp model I bought 10 years ago which I never use. It has been sitting for years. Today put in new bag and ran it continuously for 45 minutes. After I turned it of it wouldn't restart. Tried another outlet and wouldn't restart. Felt canister at back and motor housing was hot so I thought I might need to let it cool down. After letting vacuum cool off for 10 minutes it restarted. All I can assume is that the vacuum has a built in overheat sensor on the motor. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka Mighty Mite #3670 Bagged Canister. I have the same type Mighty Mite Canister and from what you are saying the must be some type of heat sensor that is shutting off the motor to protect it from excessive heat. Al of the old ones have had lower amps and did not needs the heat sensor but once the bag is full and the filter clogged; they will shut down as well. They all use a plastic hose to clean with and that even gets hot sometimes. So I suggest that you get an owner’s manual from the manufacturer on you particular model so that id if happens again, you will be prepared. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
5855 Terry Fox Way
Mississauga, Ontario L5V 3E4
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Eureka Mighty Mite 3670 Bagged Canister...
Vacuum cleaner
What brand vacuum is it?
Feb 24, 2008 | Vacuums
Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
Oct 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
109 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
