Question about HP Color LaserJet 4500n Printer
HP Color LaserJet 4500 printer
I cannot get my Dell lap top to print to HP printer, failed to print message keeps coming up. spoke w/ dell and they say i need to set up disc to redo set up. everything was working fine. i used to have a wireless connection to printer now i have hard wire and won't print. i have tried to download from hp web site but still no go.
  • 268 Answers
Here is the driver for the printer that Dell is refering to:
Simply download that and run it , it will reinstall the software for your printer and should get you going again!
if you have any problems through the procedure feel free to post a comment here and I can help you out even more.....
Posted on Oct 01, 2008
Down loading Lasejet 1320 printer for my dell lap tpp
If you plug the printer into your laptop and turn it on the " found new hardware wizard" should appear. This will help you find the software for your printer. Good luck !
Aug 22, 2012 | HP LaserJet 1320 Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
Hp4500 color laserjet. when i send a file to print the printer strats feeding out endless blank pages
Reinstall the Drivers for the Printer
Which will solve the problem
Download updated Driver Laser jet 4500
Uninstall and reinstall software Drivers will work
Open device manager - and Update drivers from there
Jan 05, 2010 | HP Color LaserJet 4500 Printer
Printer not connected to hp laptop
If this laptop and printer combination worked before, try a new cable. They often fail inside without any notable outer damage.
Sep 18, 2009 | Dell A920 InkJet Printer
My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Apr 07, 2009 | HP LaserJet 4500 Printer
HP 4500 Printer blank pages
Hi over the years on working on these printers I have found the transfer belt-kit causes this model to print blank pages i would try this
hope this helps
Dec 15, 2008 | HP Color LaserJet 3500 Printer
Failed to Print Error
Set powermode "allways on" for the lap top. Use an Usb cable no longer then 2 m. Try upgrade firmware for the printer. If still got problem use a powered usb hub between laptop and printer.
Nov 20, 2008 | HP Color LaserJet 2600n Printer
Error message on HP 2600n
Connect to it through usb/parallel from your laptop, If this works then check your settings through your wireless connections,Hope that helps
Jul 10, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 4500n Printer Logo
75 people viewed this question
Ben Johnson
