I'm trying to find out how to clean the laser lens on a 400 disc mega DVD player?
    Scholar:
  • 142 Answers
You need to disassemble the machine to see the laser. Take a cue-tip and spray windex on it. Take the cue-tip and clean the lens from the inside out in a circular motion. then immediately use a dry cue-tip to remove any excess moisture. Otherwise buy a cleaning disc...the wet variety. Good luck!!
barneyluc
Posted on Oct 01, 2008
When I try to use my dvd player I put a disc in it says loading them it comes up and says bad disc, it will also do this if there is no disc inserted into it, can you help me? I don't know the model #...
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Koss KS4110 DVD Player
How do you use a NEXXTECH Laser Lens Cleaner?
The NexxTech Laser Lens Cleaner uses six super-soft brushes to ensure thorough and reliable cleaning, without harming the delicate optical components of your disks. Enjoy your DVDs more and improve your music archive by cleaning your optics in your CD or DVD ROM. The easy-to-use audio instructions walk you through the cleaning process from start to finish. This laser lens cleaner process will prolong the life of your disc player, improve visual clarity and sound quality. Features
  • Works on CD, DVD, Blu-ray - all optical drives
  • The six brush system cleans off the entire laser lens
  • Will not damage sensitive optical components
  • Includes easy-to-use audio instructions
How to Clean the Laser Pickup Lens on your DVD Player X missing_author_image.png eHow Electronics Editor This article was created by a professional writer and edited by experienced copy editors, both qualified members of the Demand Media Studios community. All articles go through an editorial process that includes subject matter guidelines, plagiarism review, fact-checking, and other steps in an effort to provide reliable information. By an eHow Contributor
Is your DVD player malfunctioning? If you're getting a no-disc error, you may need to clean the DVD player's laser pickup. The laser pickup is what reads DVD's and allows you to view them on your TV. If you need to clean the laser pickup lens on a DVD player, follow these simple steps.
Difficulty: Moderate Instructions things you'll need:
  • Isopropyl alcohol
  • DVD lens cleaner
    • 1 Make sure the laser pickup lens is actually the problem. There are a wide variety of reasons that a DVD player might not read a disc efficiently. The disc could be scratched or dirty, for example. Test the DVD player with a disc that you know works before trying to clean the lens.
    • 2 Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
    • 3 Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens.
    • 4 Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection.
    • 5 Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab.
    • 6 Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process.
May 05, 2011 | Televison & Video
Tried to use a laser lens cleaner disc to clean my player, once loaded and inside the player I went to press play and follow the instructions, but my player stopped running and a (check disc) appeared on...
I have this DVD Cleaner from All sop Inc as well,this disc only do very miner cleaning to the DVD player Laser eye.Did not work on my DVD player.I have to take the DVD player aparts,littery take some Q tips and dips it in with some rubbing alchahol to clean the DVD laser eye itself.After littery take the DVD player aparts and clean the laser eye itself.If the DVD player still doesn't read and play any DVD discs?The DVD player laser eye is bad,not worth repairing,the brand new DVD player is cheap,cost only like $40 brand new one.
Nov 23, 2010 | LG DN798
Can not play disc
You can try a lens cleaning kit. If it is the kind that comes as a disc all it will do is lightly brush the lens which may not remove all the debris. If you disassemble the player you can easily get to the laser lens. It will usually be fairly accessible once you remove the DVD case. Sometimes it may be located within another box that needs to be disassembled before you can gain access to the laser. The laser unit will be located on a rail system and will have a small clear lens about the diameter of the eraser on a pencil. You can gently clean it with a cotton swab and lens cleaner or rubbing alcohol works just as well. Try that first before buying the lens cleaning kit or replacing the player.
Jan 07, 2010 | Sony DVP-NS715P DVD Player
Samsung dvd-v6800 not reading disc
hi..
Try buying a Laser Lens Cleaner Disc from Wal-Mart, FYE music store, or any other place that might sell DVD players. Your Laser Lens that reads the DVD'S is full of dust. Try using the laser lens cleaner disc i mentioned to clean the laser lens...
thank u
rate me
Aug 23, 2009 | Televison & Video
Every DVD I insert in my DWM 400 comes up
have you tried cleaning the pick- up lens with the lens cleaner.
Aug 04, 2009 | Sanyo DWM400 DVD Player
PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Feb 10, 2009 | Televison & Video
How do I clean the laser of a coby 224 dvd player?
Step1Make sure the laser pickup lens is actually the problem. There are a wide variety of reasons that a DVD player might not read a disc efficiently. The disc could be scratched or dirty, for example. Test the DVD player with a disc that you know works before trying to clean the lens. Step2Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails. Step3Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens. Step4Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection. Step5Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab. Step6Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the processalso click this link for more help http://www.ehow.com/Search.aspx?s=How+do+I+clean+the+lens+of+a++dvd+player%3F&Options=0
Nov 29, 2008 | Coby DVD-224 DVD Player
Disc error
It is possible that there is some dirt on the laser lens. With great care the laser lens can be cleaned.
eHow, Clean Laser lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
If cleaning the laser lens does not fix it, there is the possibility that the laser unit and or its assembly, or the related electronics has a fault.
Jerry G.
May 24, 2008 | Sylvania SSD803 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
