Question about Sony PlayStation® 3 (60 GB) Console
Ps3 hdmi sound problems
I bought a sony hdmi cable for my ps3. The visual works great, but when i load up a ps3 game, the sound sometimes works and other times it does not. I have hdmi selected in sound settings, so im not sure if if its a problem with the ps3 or the chord.
  • 2 more comments
  • Anonymous Nov 13, 2008
    i need help
  • Anonymous Dec 21, 2008
    help please....
  • Anonymous Feb 08, 2009
    i have no speech through my ps3 when i use a HDMI cable with games or dvd's
  • Anonymous Mar 29, 2009
    my sound just stops half way through the movie?
Its the auto select on your tv or receiver just turn them off then back on it worked for me
Posted on Nov 17, 2008
All picture and no sound
Rick:
simply unplug--then replug--your HDMI cable. Or also go into the audio setup menu and reapply the "automatic" setting for HDMI to get the sound to work. I don't know if Sony can do anything about this or not in a firmware upgrade, but what it can do is try to simplify the labeling on some of the sound settings.
Let me know
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
Crackling sound on PS3
the laser is starting to wear out. it cant reda the audio fast enuf to keep up with the visual side of the game resulting in crackling momentary hissing or cutting out of music
Jun 03, 2009 | Sony PlayStation® 3 (80GB) Console
Sony Surround Sound, LG TV and PS3 connection problems
sounds like you are going to have to get the component cables for the PS3, you can get them on amazon, the only thing about the component cables is that the quality cant go as high as the HDMI cable but its close. but thats the only way i can tell you to have surround sound with your PS3
May 09, 2009 | Sony Playstation 3 (PS3) Console
Ps3 static audio
I just bought my PS3 and noticed this exact problem, Go into your audiosettings click hdmi. then go to manual. Uncheck Dolby 5.1. save your settings. This fixed the static for me. Sony should fix thier 5.1 drivers
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Problem
i have my picture going through the hdmi and the sound going through the scart. plug the scart into the back of the ps3. then the white and red wire are into my tecnics sound system and it works perfectly you just need to set it up in the sound options in your ps3. which is very easy. just select scart in the sound options. hope this helps you.
Bad sound through HDMI
Is it only in Games or Movies?
Try checking the cables. (obvious I know but it must be said).
On the XMB (Cross Media Bar), go to settings on the left. Scroll down to "Sound Settings"
Choose "Audio Output Settings", then "HDMI", then "Auto"
If that doesn't fix it then choose manual and the most basic outputs first;
-Linear PCM 2ch. 44.1KHz
and
-Linear PCM 2ch. 48KHz
Depending on your surround sound setup your could get away with other options as well. Fist determine if your setup is 5.1 or 7.1, DTS or Dolby Digital. Then start with the lower KHz settings and work your way up.
Dec 12, 2007 | Sony Playstation 3 (PS3) Console
Picture goes to a lime green fuzz and then no piture or sound!
which AV connection are you using? HDMI or the cable supplied with the PS3, If using HDMI, you have to set the PS3 visual settings to HDMI, to do this, use the cable supplied with the PS3, and have the HDMI cable plugged in. Then while using the cables supplied with the PS3, switch the settings over to HDMI, then change the TV's input selector to your HDMI and confirm the settings changes. Hope it helps take care
Oct 17, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
251 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
