Question about Whirlpool AD50USS Dehumidifier
Does not dehumidify and very noisy
My 3 year old AD50USS makes a lot of noise but does not dehumidify. It is not worth repairing as the cost of having it serviced is about the same as buying a new one. I thought that I would take it apart and see if there was any obvious problem. I can't get the top recessed screws off as my sockets are too big to fit into the hole. Does anyone know what size (brand) socket I need to use to remove these?
elhomspam
  • 58 Answers
SOURCE: dehumidifier
Check the coils for partial icing. Id recommend unplugging it leaving it to defrost and plug back in. If still not working check coils again. If partially frozen you have a sealed system leak. The fan being noisy can be a sign its not working and not spinning high enough to cool coils for proper operation. Try taking a shower and leaving dehum in with you, After a shower leave in for about a hr, if water collects you prob have a failed fan. Id recommend repurchasing if OOW. Due to costs.
Posted on May 01, 2008
IrishDruid
  • 2712 Answers
SOURCE: Instructions
Here you go:
http://www.manualnguide.com/manual-get/9742/
P.S. - You can rate a solution with one of fourratings as explained under (remember that at times a bit of to and fro dialoguemay be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on Sep 28, 2008
heatman101
  • 43501 Answers
SOURCE: whirlpool dehumidifier makes a lot of noise when
When the compressors start to go bad they often start to get very loud also...the cost to replace the compressor will probably be more then a new unit...
Also check out this tip about dehumidifier problems...
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
Posted on May 04, 2010
Testimonial: "thank you for your help .it has been noisey for too long a time to be the compressor but you are probably correct on this..it started to make noise after the very first year of buying it. We did buy it in 2006.."
heatman101
  • 43501 Answers
SOURCE: Kenmore dehumidifier 580 5370 1300
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Posted on Jun 18, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Whirlpool dehumidifier, model number
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Posted on Aug 29, 2010
We have a 40-pt Crosley purchased in 2005. Gave us 6 years of perfect service. It stopped working recently; it will not turn on. No lights, no response...dead. Is a unit this old worth repairing? ...
Shinn, I'd say you've gotten your monies worth out of 6 year old dehumidifier. Most of the time, it's more expensive in the end, to repair one than it is to purchase a new one. With that said, I'd vote for purchasing a new one. Just take as good of care of the new one as your did the old one. Obviously, you performed preventive maintenance on the old one and that's very important. Which makes you the exception to the rule, that most consumers don't take care of what they have and are astonished when an appliance fails.
Keep up the good work!
Mar 26, 2011 | Crosley Dehumidifiers
My 880 home dry is around 15 years old now and when on makes a loud squeaking noise, what is it and is it worth repairing , other wise works fine .regards
sounds like the fan - its worth taking apart and seeing which bit squeeks, if its the bearing try a small amount of WD40 first. try not to get any on the motor of electrics. You can by an electrolube spray if is is the Fan... Well worth taking apart, the latest EBAC models are of very poor quality.
I also had a Homedry for 15 years and the cabinets started to root first... I've had three 2560e's since all replaced under warranty - pcb failures...
Nov 28, 2010 | Ebac HD880 Dehumidifier
I have a Whirlpool dehumidifier, model number AD50USS0. The unit runs but does not dehumidify. There is no water in the reservoir and the part that makes the most noise is silent. The fan operates just...
heatman101
Aug 29, 2010 | Whirlpool AD50USS Dehumidifier
Whirlpool dehumidifier does remove water
indicates a gas leak and there is insufficient gas in the system
Oct 19, 2017 | Whirlpool AD50USS Dehumidifier
Whirlpool dehumidifier makes a lot of noise when running and vibrating, dehumidifier is only 4 years old it does take out the water but very noisey any way to quiet it down?
May 02, 2010 | Whirlpool AD50USS Dehumidifier
Trips circuit breaker. when it runs, it does not extract humidity.
this isn't what you want to hear but it sounds like you have a bad compressor . if the unit is less then 1 year old then find a local warranty service and they will fix it for free. If it is older then 1 year old it will cost more to fix then the unit is worth.
Apr 24, 2010 | Whirlpool AD50USS Dehumidifier
Dehumidifier only two years old now doesn't extract water from air since I just started it up again for the summer.
Problem is that you bought a dehumidifier made by the Korean/Chinese manufacturer LG.
Search the web and you will find that you are just one of many whose dehumidifier worked the first year but now draws no water out of the air even though it makes all the right fan and compressor noises.
Most common problem is that all the Freon refrigerant escaped, apparently because the copper tubing cracked and leaked. Penguins beware, there goes the Ozone Hole!
It cost me $14 and an afternoon of investigation and testing of my LG 504EL dehumidifier to figure this out. The fix-it web site "Just Answers" said that it wasn't worth fixing after I described all the symptoms. Tomorrow I will go to the local LG fix-it shop and try to get a replacement to tide me over until I can find a reliable dehumidifier.
Sadly, last Fall I took my 25 year old Westinghouse (made in America) dehumidifier to the dump. Even though it needed me to tune it up every year or two, at least I could fix it and it kept on working for 25 years.
enterich
Jun 28, 2009 | Whirlpool AD50DSL Dehumidifier
Compressor does not start
some of these units have a 5 year compressor warranty on them including labor worth calling sears and seeing if it does have the 5 year on the sealed system
Apr 09, 2008 | Kenmore 53509 Dehumidifier
Whirlpool AD50USS Dehumidifier Logo
91 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
