Question about ASUS Computers & Internet
How to install the recovery dvd rev.1.5 - ASUS Computers & Internet
    Scholar:
  • 67 Answers
Boot from CD and it will give you all instructions ..That's easy ...You can change boot prioroty from BIOS setup ..Let me know if u need any other help
Hope it helps
Bye n GOod luck
Posted on Oct 01, 2008
How to restore from recovery disk after installing a new hard drive
The procedure to restore from recovery disk will vary according to which computer you have. Usually you insert the recovery disc in CD / DVD drive after selecting boot sequence 1 from CD/DVD in Bios. You then push the power on button. Once windows boots from recovery CD it will continue with building up the new hard drive.
Sep 03, 2014 | Computers & Internet
0XE0EF005D
The issue can be caused by the damaged system files or hardware device.
I suggest trying the following method to troubleshoot the issue:
Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Please continue with the following instructions if the above suggestion does not help:
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ..." appears.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. (Click the operating system that you want to repair), and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type "chkdsk /F C:" (without quotation marks) and click Enter.
8. Restart the computer and have a test.
If the issue still exits, please move to the below steps:
In-place Upgrade Installation
Technically, you won't lose any data to take an In-place Upgrade Installation. In order to avoid any unexpected problem, I suggest you backup your data before taking In-place Upgrade Installation.
1. Start the computer by using the current Operating System.
2. Insert the Windows Vista DVD in the computer's DVD drive.
3. Use one of the following procedures, as appropriate:
• If Windows automatically detects the DVD, the Install now screen appears.
Click Install now.
• If Windows does not automatically detect the DVD, follow these steps:
a. Click Start, type (Drive: )\setup.exe in the Start Search box, and then clickEnter.
Note: (Drive: ) is the drive letter of the computer's DVD drive.
b. Click Install now.
4. When you reach the "Which type of installation do you want?" screen, click Upgrade to upgrade the current operating system to Windows Vista.
Installing and reinstalling Windows
If both of the above two methods do not work on your issue, please contact the manufacturer to check the hardware.
Regards,
Thulasiramki.
Feb 14, 2014 | Computers & Internet
Issue with opticaldrive and creating factory default disc
most of the time to create recovery disks you have to use about 7 cds, 2 DVDs, 1 blueray or double layer. some systems also use DVD+R, when you start the disk creation it would tell you what it requires, your best option (if compatible) would be using 2 DVDs-R. On the other hand if you inserted the cd and it turned a few revs. most likely it is ruined already so you have to use a new disk.
if it is a brand new pc you should be able to use DVD. here is a tutorial for HP and it is pretty similar for most computers
http://www.wikihow.com/Create-Recovery-Discs-for-Windows-Vista-in-HP-Recovery-Manager
if it works for you don't forget to rate me
thx
Apr 28, 2010 | Gateway Computers & Internet
I accidentally erased my dvd driver for my toshiba satellite m40/m45 series laptop, and I cannot even use my recovery disc to reinstall it, because I cannot use my DVD player to use my recovery disc.
Option 1: Download the DVD drive from the Toshiba website for free and install it.
Option 2: If you could manage to a get a external DVD drive that can be connected by the USB and use your recovery disk to get a clean install.
The first option would help to fix the problem withouth going for a clean install. But in case you are going for Option 2, then I would recommend you to take necessary backup of all your data.
Mar 07, 2010 | Toshiba Satellite M45-S351 Notebook
I have a Gateway Notebook W3203u with problems in my Windows OS (vista) and cannot get it to boot. I did not make a backup DVD as I didn't have an external DVD to make one. Now I have no way to recover my...
Mostly the company provided recovery DVD re-partitions or at least formats your hard disk. In both cases your loose your data. If you have some data you need try this workaround.
You need a Vista installation DVD.
Here is what you do
1. Boot from the dvd and select to install vista.
2. You will be notified that your old system will be backed up to a Windows Old Folder on C:\. Accept this and proceed with your installation. (DO NOT PERFORM ANY FORMATTING OR PARTITIONING or else you will loose your data and recovery.)
3. Finish the windows installation.
4. At this stage it is recommended to install a good anti-virus with latest virus definitions updates in case your problem was caused by a virus.
5. When done open my computer and open c:\ drive their you will find a windows old folder with all your old files back up. Back up your files to an external media ( A CD, DVD, or external hard disk)
6. In this folder search for the word recover. from the list you will find either a recovery disk creator software or your computers recovery software itself. I have tried many models and this program launches you when you trigger it here. If the CD/ DVD creator works for you well and good. You don't need to read any further just go on create your DVDs. Else look for Recovery and open the program and continue the wizard. Make a Full factory recovery. (Be sure to make a back up of your old files before doing this). Good Luck
Nov 22, 2009 | Microsoft Computers & Internet
Eee 1000H will not start from DVD
DVD could very well be faulty first few "grooves" often fail
Sep 13, 2009 | ASUS Eee PC 1000H Laptop
DVD no video output
This was probably caused by an update,just reinstall your DVD encoder/decoder software.
Jan 27, 2009 | Computers & Internet
A friend install my mother computer. how to jumper
Set the jumper to recovery or to clear
CMOS Jumper
1-2 - Mostly normal
2-3 - Clear
0-0-0 Recovery no jumper
Its a basic conscept it can change according to your bios manual you follow - Trace the cmos jumper exactly dont short any other jumper
Jul 25, 2008 | EliteGroup Computers & Internet
Acer 5050
by default acer 5050 have 3 partitions
1. OS partition (C)
2. Data (D)
3. Recovery partition (hidden).
If you deleted recovery parition, you can't recover your C parition using Alt+F10. Your only option is recovery from cd/DVD recovery that you created. if you didn't create the cd/dvd, you can call acer support to buy the recovery dvd.
Mar 16, 2008 | Acer Aspire 5050 Notebook
Computers & Internet Logo
22 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
