Question about Dell Latitude Cp, Cpi, Cpx, C600, C800, Inspiron 3800 8000 4000 601212 CD-ROM Drive
Dell C600 Hi, my battery will not charge. I have moved my battery to the cd rom side and it still will not charge it says idle on the bios. Bios is A23 and i have been told to revert back to A12 then the battery will charge.My problem is trying to download as Dell zip file asks for a password or the computer says it will not update as this is the same or earlier so it stops p.s the battery is new
  • Anonymous Oct 03, 2008
    Hi, My Dell C600 will not charge either. Two batteries that have been working quit charging. The computer runs on ac power and battery. the batteries are getting low. Windows xp says charging, but no change. BIOS is ver. A23 also. I am letting it all cool off to see if it works again. next I will try to revert to an earlier BIOS. Why A12 aren't there others in beween that and A23? Is it possible the charger is broken or a bad motherboard? Is there any component that can be changed to fix this? I put in another hard drive with win xp new and still the same problem. So it's not a windows problem.
Here goes, first download the A12 BIOS from this page or others,
http://drivers.softpedia.com/get/BIOS/Dell/index5.shtml
Then, Run this file to make a bootable bios floppy disk. Reboot the laptop floppy will start dos mode, the updater will detect any bios newer then A12 and say finished without changing anything and come to an a: prompt.
type dir for a list of files on the floppy. If your typing gets you wierd symbols try holding the Fn key (lower left) lookfor the filename C600_A12.exe or somthing like this. type it at the a prompt exact. The bios flash will check system bios and ask your permission to revert back to A12. say Y.
Computer will reboot. take floppy out.
My batteries charge grat now, but I don't get all ythe settings pages in Bios that I should, It seems to hang when i enter Bios. Laptop works fine though. i have installed and tries all bios from A12 yo A23, the A12 seems to be the best. No problems from winXP.
Posted on Oct 04, 2008
Can i boot from usb
I'm sorry but the answer is no.
You only have floppy, hard drive and cd-rom options. With some Dell models the USB is seen as a secondary hard drive from within the BIOS so maybe (if your bios supports it) you can change boot order there.
Usually thats not the case so you mainly have to boot from the CD/DVD to install or run a DOS or linux command.
Regards.
Feb 09, 2010 | Dell Latitude C600 Notebook
How to change the mother board bios setting to default setting
start your computer, continously pressong, f2 and del key, go to bios set up,, set default settings, save it, then restart your computer, by pressing ctrl+alt+del
Jan 03, 2010 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
MY DELL LATTITUDE C600 TURNS OFF AUTIMATICALLY
hi there, you can try this unplug the powercord from the pc and remove the battery and than press the power key than replace the battery adn plug in the power cord and let it charge for a hour or so and than try it again. if it boots good if not try to press the del key right after you turn on the unit and check the settings of bios to see what they are set at and try to set it to default or failsafe than save on exit and reboot and see what that does
Dec 18, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
It turns on and shows the BIOS screen? Can you access via F2? If it shuts down, check the RAM and RAM slots! Wrong CPU can also imitate a dead machine
Dec 07, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude C600 Laptop
Did you try to boot into the BIOS and load the default settings?
Pls check if the hard drive is recognized in the BIOS first.
Sep 02, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell c800 won't start
Well, tried resetting all power to the board and then rebooting? Even CMOS batt? Try any video related fixes with the cheapest and simplest first, always... Check the output VGA port and S-video for example
Jun 23, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Fit a new harddrive in an old laptop
Pls try:
1. When the Dell logo screen appears press the F2 key to enter the BIOS?COMS; or
2. There are some Dell Latitude that uses Fn + F1 (while booted).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell c800 bios
It shouldn't be the Dell Latitude C800 Battery problem,it maybe the KEY Broad or the OS itselves problem.
May 17, 2008 | Dell Latitude C800 Bios Battery (IMP61135)...
Dell c 600 will no charge the battery
try load defaults on bios by goin F2 on dell splash screen. if still no go, remove battery and leave adapter plugged in. if no power while adapter only plugged in, replace adapter, if has power while adapter plugged in, replace motherboard( since you already replaced the old battery).
Nov 08, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computers & Internet Logo
309 people viewed this question
Alun Cox
