Question about Waring Pro WC1000 Coffee Maker
GFI trips the GFI, but works fine on a NON GFI circuit, only problem is the long cord (25 ft)
  • 706 Answers
Hello Joesal,
A GFI receptacle senses and imbalance between the hot ( line voltage) feed and ground. There should be no current sensed on the ground. This protection feature will disable the line voltage in milliseconds if it sense current passing thru to ground. The intent is to sense current flow to ground and in the event that you are that path ( meaning current is flowing thru you as a ground)..it disables that line voltage in milliseconds to keep you from being electrocuted. You have either a bad GFI receptacle or there is leakage current getting thru to ground. In either case, its a good idea to determine which is the problem.. I suggest you try your coffee maker on another GFI receptacle in your home ( perhaps in the bathroom or basement) to verify the coffee maker isn't malfunctioning. If it is,, then you may want to discard it or if you are elecrically handy, repair it,... Do not compromise you or your familys safety with these things.. Be careful and good luck..
In addition,if you do run the coffee maker off an extension cord, make sure it is properly sized for the current that your coffee maker requires.. I wouldn't use any extension cord less than 14 gauge ( #14 )
Good Luck..
Posted on Oct 02, 2008
Clarke power washers 150
Need more info:
What fuse? the one at the end of the cord on the pressure washer? Or the circuit breaker on your house?
If it is the one on the cord it may have gone bad. To test replace it with normal plug (non-GFI) and plug it into an outdoor or bathroom GFCI (GFI) outlet. If it still trips that outlet then there is a ground fault in the device which may be minor or major.
If it is a home circuit breaker remember that electric pressure washers use a lot of power - typically 1500 watts. If anything else is plugged in it can trip the house circuit breaker.
Jun 04, 2014 | Garden
Purchase new 32'' tv 2-day ago, will not work in a GFI plug outlet trips GFI each time you reset, is there something wrong with unit? works fine in a non GFI outlet
Good News!!! GFI outlets are made to trip when a large amount of power is pulled through them. A GFI is basically a small circuit breaker.Your television set is probably just pulling more amperage than the GFI is rated to handle. That means the GFI is working properly And so is the TV!
May 05, 2011 | Televison & Video
I cleaned my Kenmore 59658692890 and moved it to the garage. When I plug the fridge in the GFI trips. Any suggestions?
Refrigerators has starting amps that do not done well with GFI circuits.
GFI is designed to trip with a power surge.
Refrigerators have power surges.
Find a non-GFI circuit to plug into.
Jun 27, 2010 | Kenmore Refrigerators
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
Westinghouse RJ442 fridge was working now tripping
Is it a GFI that it is tripping. If it is using an extension cord try plugging into a non GFI outlet.
Feb 03, 2010 | Westinghouse Refrigerators
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
Trips GFI circuit brakers
First of all, lets clarify what is going on. You say it trips the GFI breaker, so I'm assuming that it is not a GFCI receptacle that you are plugging into. So you are going to the electrical panel and resetting the GFCI breaker.  If it were a GFCI receptacle, have you tried other loads in this receptacle for 30-40 seconds, ie: Toaster, hairdryer, coffee pot? If everything works fine then there is something wrong with the ESP8XL. It would seem that there is a leakage path to ground from one of the conductors. If it is new, bring it back.
Jul 30, 2009 | Breville ESP8XL Espresso Machine
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Jan 02, 2009 | LG WM2016C
Waring Pro WC1000 Coffee Maker Logo
225 people viewed this question
Top Waring Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Are you a Waring Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
