No output from speakers in car.
Unit works, speakers are connected. Have just swapped car stereo. Still no sound from any of the 6 speakers. No apparent damage to wiring. Connections seem fine and pretty solid. What's wrong? It should be straight forward. If the audio unit in one stereo doesn't work, the new stereo should. If one speaker is damaged then at least 3 others should still work. The car has had bodywork done recently but both speakers are still connected on the side the work was done. Any ideas?
  • 89 Answers
Sounds like a couple speakerwires could be crossed/shortcurciting somewhere...;)
Posted on Oct 01, 2008
I only have left channel on speakers working have tested speakers ok, swapped pre amp boards still one channel, swapped output boards the same. What could it be? Barry
is there Sound stage output is stereo if stereo then one side is missing or broken link from ic to speaker, If mono output then use with one side 2 speaker parallel.
May 20, 2015 | Audio Players & Recorders
Why would only 5 of 6 speakers work after new head unit car audio install?
Either that speaker is not connected or, the speaker is blown. To test: Disconnect that speaker from the stereo and, using a 9volt battery, tap the speaker's + and - to the battery's + and -. You should hear a "pop". That would indicate that the speaker works. DO NOT connect the 9 volt battery to the stereo side of the speaker wire!!!! 3_24_2016_7_22_43_pm.png
Mar 10, 2015 | Car Audio & Video
Gt5 12 inch 275 watts how many watts of amp best?
Depends on what output your stereo is. If you underrate the speakers (speaker watts is less than stereo output), the unit will sound louder for a while, then you end up blowing your speakers with the excess distortion. If you overrate the speakers (speaker watts is higher than stereo output) the speaker will not operate correctly and the distortion can damage it also. Its best to get a close match. Slightly higher is better. It is important you know actual wattage output not PMPO ( Peak music power output) A lot of stereos are rated at PMPO. The higher number sounds great but in reality, the figure is the MAX output and by then the sound is distorting badly. Distortion ruins more speakers than anything else...
Oct 11, 2013 | JBL GT4-10 Car Subwoofer
I have a sa-ak320 stereo that was left at my gf's
The 6 ohm speaker would make it slightly louder but won't solve the problem, you are right the stereo has bad audio output ic, and there is trouble with the cd player. I would use it until it goes, and get a brand new unit, not cost effective to repair.
Apr 15, 2012 | Panasonic Audio Players & Recorders
I have a stock stereo and two subs with an amp in the trunk. Also two alpine speakers in the rear. Whenever I turn my balance to the left my subs don't play. What's wrong?
Hello.... I am sorry to hear you are having problems. The reason for this is that since you have a stock stereo, the shop (or person) whom installed the amp and subs used a line out converter. What this part does is allows the connection of RCA cables to the factory head unit. Almost all bass signals are always in stereo, so since you were only hooking an amplifier for just subs, you can actually just connect to just one of the rear speakers instead of connecting to the right and left. Just makes the install a little quicker. There is nothing wrong with this as I usually do the same thing in our shop. However, if you are going to be using the balance control, then you will need to go back to the shop and have them hook the converter up in stereo (to both rear speakers). Hope this helps!
20 year car audio/video installer
Bay manager
Mar 15, 2011 | Alpine Car Audio & Video
My jvc mx-d622t shelf stereo simply stopped working. No power at all , Course I do have 6 speakers hooked up to it, just added the third pair the day before it stopped working.
Are these speakers compatible or are you just adding speakers because you have them hanging around?
If you have effectively less than 6 ohms of impedance on any channel you may run into problems and the unit may either die or protect itself by refusing to stay ON.
It's fairly obvious that if you do X and undesired Y happens you might want to UNdo X and rethink it.
May 29, 2010 | JVC UX-GP5 Micro Stereo Audio System Shelf...
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Connect Creative 5.1 A500 speaker system to Phillips DVD 3256
Just buy two connectors(shown above). Its having two holes upside.
1. Connect the connector to one hole of the other.
2. Connect the audio cable to the dvd.
3. Then connect the connectors to the other side of the audio cable.
4. Lastly, connect the three stereo output cables of the Creative speakers to the three holes of the connector simultaneously.
I have tried this at home with my Creative Inspire M5300 speakers and philips dvd. All the five speakers are working.
Rovan C
Jan 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
Stereo speaker suddenly stopped giving sound
You will need to take the speaker apart and with an ohm meter or continuity tester, measure the resistance of the speaker right at the speaker to see if the speaker is open. if it is you have no choice then to replace the speaker. If the speaker measures a low resistance, measure the wires froom the speaker to the output wires or terminals. Some speaker manufacturers install small fuses inside their speakers. Good Luck
Mar 29, 2007 | AAD E-30 Main / Stereo Speaker
206 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
