I forgot my paaword with myway,emal,They said they would emil it to my juno address.But juno says I don't have a Juno account.Juno said I'm on Net zero.There is no way for me to get this informatoin to Myway? Beverly Olsen.My emil address is Bjolsen@myway.com my Net zero is Nannybev@netzero.com.Please help me.My has no phone numbers and no customer service.
    Sergeant:
  • 268 Answers
You can try going to this page for a password reset:
http://registration.myway.com/login_help.jsp?return_url=http%3A%2F%2Fmy.myway.com%2Femail_redir.jsp
I entered in your e-mail and it proceeded to ask me a security question , obviously I don't know the answer so I can't answer it for you , but I am assuming you will at least be assigned a temp. password once you get passed that...
Posted on Oct 01, 2008
How do i get into my junoe-mail?
Juno My Juno Personalized Start Page Sign in
click on link above and click on user id and enter email address then click on password and enter password then click sign-in
good luck.
Feb 07, 2015 | Computers & Internet
Tip
How to Fix Juno Webmail Error 691: Invalid Username and Password
When using the Juno webmail services, you might get the connection failure issues, as the member ID or the password you have entered is wrong. This problem is also known as the Error 691: Username and password incorrect. At such time, you need to input the password all in lower case letters. If the password isn't working, check that the Caps Lock key isn't active. If you forgot the password, ask the solution of experts just by dialing the Juno customer phone number. As many factors can cause error 691: invalid Member ID or Password, so follow the listed guidance to diagnose the cause of the error and solve them out instantly.
1.Check the Member ID and Password
Make sure that you're entering the correct Juno user ID and password. Also, ensure that you have entered the password into lowercase letters. If your password isn't accomplishing, make sure that the Caps Lock key hasn't yet been activated. If, however, you forgot the password, then you can change it under the supervision of experts.
2.Ensure that Juno Webmail Account has Correct Configuration
If your Juno webmail account was created correctly, the new account information should appear at the end of the confirmation screen. Additionally, if you have logged into the account successfully as earlier, it must be correct.
3. Check that you haven't set the password in Juno software
Do you have the program to configure to remember your Password automatically? In most cases, the password present into the Juno program may be changed. It can happen, if, for instance, you have pressed a key accidentally on the keyboard. If you're sure that your account password is correct, remove the currently set password from the software and re-enter it. This step would solve the error if the password were changed accidentally.
4. Make sure that the access number is correct
To make a successful login to the Juno webmail account, it's necessary to make sure that the access number of your area is valid. When choosing the access number, it may be the area code or placed in the general geographic region rather than local numbers. You may experience extra telephone charges if you select access numbers that aren't covered by the local calling plan.
Note: - You're only responsible for several telephone charges associated with accessing the services. Juno will not refund you for such costs, such as toll charges or long distance.
5. Check Juno webmail version
Do you have the new edition of Juno webmail program? If you're unsure about the Juno version, you can seek the help of IT professionals or go to the Juno official site to know the step-by-step direction to check the version.
6.Test the encryption settings
If you're running the Windows 98, 2000, ME, or XP:
    •Double-click on the 'Computer' icon on the desktop, followed by the 'Dial-Up Networking' icon.
    •Click on the Juno icon to select it. Choose 'Properties' option from the 'File' menu.
    •Choose the 'w Server Types' tab and make sure the 'Require encrypted password' option is not checked. Click 'OK,' and then 'OK' again. If you're still facing issues with the Juno webmail account, call on the Juno support number and seek the technical assistance to solve out all problems instantly and efficiently.
How to Fix Juno Webmail Error 691 Invalid Username and Password
on Apr 13, 2017 | Miscellaneous
Tip
3 Quick Solutions to Repair Juno Webmail Script Error message
If you have an Ad-blocker or a popup blocker installed on your computer system, you may get many script error messages while connecting with the Juno Webmail. You can prevent these mistakes from encountering by configuring the pop-blockers / ad-blockers correctly. If you're often getting a Script error message whenever try to start Juno or log into the webmail account, then you will require configuring the ad-blocker programs to operate with Juno webmail; otherwise, you may face the Juno sign in problem. There are three methods to do that:
    1.Add Juno Mail to the exclusion list of your ad-blocker
    2.Set up the ad-blocker to enable banner ads
    3.Disable the filtering feature in the ad-blocking program If you're using the AdSubtract tool, you should follow the instructions given below. In the case of any other pop-up blocking or ad-blocking software, refer to the documentation of your blocker tool for the accurate guide on configuring the software to enable ads from Juno Mail. You can get connected to the Juno webmail support experts and solve these error messages in a proper manner.
    Solution 1 - Insert the Juno Webmail to the Bypass Site list
    If you want to add the Juno website into an exclusion list, right-click anywhere on the web page and choose the 'AdSubtract: Bypass Site' option. You may require repeating this procedure on other Juno web pages on which you get the script error messages. On the other hand, speak with the Juno professionals to repair your email account issues.
    Solution 2: Configure AdSubtract to enable banner ads
    This solution will fix the script error messages that can prevent you from accessing your Juno email account, but will also cause in other banner advertisements showing on other websites you access.Here's how to setup AdSubtract software to allow banner ads.
      1.Launch the AdSubtract program and click on the 'Block' icon.
      2.Deselect the Banner Ads field from the selection on the left.
      3.Click the 'OK' button to save and apply the changes. If this workaround doesn't work and you're still getting the script error messages, then either you can get in touch with Juno customer care executives or go to the next.
      Solution 3: Disable AdSubtract tool filtering
      This workaround not only resolves the script error messages for the Juno webmail site but also causes in disabling all of the AdSubtract's filtering efficiently.
        1.Launch the AdSubtract tool.
        2.On the main dialog window, click on the 'Disable Filtering' option under the 'Ad Blocking' section.
        3.Click the 'OK' button to save and apply settings. However, if you still have any kinds of technical issues with your Juno email account, or continue to face the script error even after attempting all these solutions, or any further queries, it's highly recommended to call on the Juno webmail support phone number and ask the help to solve all Juno-related issues within a short span of time.
Juno Customer Support Phone Number
on Apr 11, 2017 | Miscellaneous
Gmail replys going to my juno account
Somewhere in your gmail settings, there is a "Reply to" setting. Change that from the Juno address to the gmail address.
May 26, 2014 | gmail.com
We changed our email address so how do we change that in our account? It was tkmanning@juno.com and now it is tkmanning7@gmail.com
Login to your paypal account then go to My ACCOUNT then move your mouse to Profile then click
Add/Edit Email. Click add email and enter tkmanning7@gmail.com then choose that email and make it primary. After that go to your gmail email and check if there is a confirmation email. You might want also to go to your juno email and check if you still need to do extra verification. If none that you are good to go. You don't need to delete your juno email as you need it for login in to paypal. All future transaction your new email will be used.
Sep 08, 2011 | PayPal Accounts
How to Set up Juno Email in Microsoft Outlook2007
Tools > Account settings > E mail accounts > Change > More settings > Outgoing server > Check the box which says > My outgoing server says authentication . Finish
Apr 21, 2009 | Microsoft Office Outlook 2007: Windows
Last my juno password cause by a tech' organising computer files
Send an email to password@support.juno.com. You will receive a response in one business day.If you write from a non-Juno email address, we ask that you supply us with your Juno usernameand your 4-digit PIN for verification purposes. If you are a Juno Platinum member you may choose, instead, to provide us with the last 4 digits and expiration date of the credit card to which you bill your Juno account.
If you don't have email access, please call our support hotline at 1-800-654-JUNO [1-800-654-5866]. You'll be asked to provide your Juno account number and your PIN.
Mar 26, 2009 | Microsoft Office Outlook 2007: Windows
Trying to use outlook for my juno email
Hi Kuhntl,
Please send a mail to juno admin, to activate POP/POP3 for your e-mail account and just find out the name of POP and SMTP server.
I Guess it would be pop.juno.com and smtp.juno.com
Now setup your mail account either through control panel or outlook options. with the following information
  • your name
  • pop server name
  • smtp server
  • your juno email ID
  • password if you want computer remember your password (not recommonded)
pl contact having probs
Thank & bye
Zulfikar Ali
Mar 07, 2009 | Computers & Internet
URL for Juno?
what version of juno are you useing.
Oct 27, 2008 | Computers & Internet
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
