Pioneer NS-DV88 System
Problem for Pioneer NS-DV88 System
2.1 out of the needed 5.1
By kioner - usenet poster
I decided to purchase my HT system in parts, opting for higher cost items and a slow build over time rather than a HTIB system. Now I have 2.1 out of 5.1 sound with two front speakers and a sub. My old bookshelf system has a pair of speakers with some sort of proprietery wiring. Two different sets of what appears to be generic speaker wire runs out of the back of each speaker, i.e. each speaker has four wires. I assume that this is beacuse the receiver unit powered two different speakers housed in the same same speaker box. Perhaps a bass unit and a tweeter?? My question is this, can I splice in addtional speaker wire to the proprietry wiring and use them as temporary surrounds??
Same Problem
May 19, 2008
-   How do i open the speaker cabinet so that i can fix my speaker. I paid alot of money for this and I should be able to fix it or get some real help on how to fix the problem.-   Guest
Solution #1
posted on Jan 12, 2008
Not Rated)
KEM827
Rank: Apprentice
Rating: 0%, 0 votes
My system was giving me the same problem. But, when I reset the system to the default settings the 5.1 surrond returned. Go to the Preference page in the setup, and change Default to Reset. This will restore all the factory settings, and 5.1 should return.
Was this helpful?
Yes
No
Solution #2
posted on May 30, 2006
Not Rated)
jessie25
Rank: Apprentice
Rating: 0%, 0 votes
I would try to figure out EXACTLY what those wires are. First--if you can't open the speaker cabinets without too much trouble, then trash them. Even if you buy some old used stuff, it'll be a cheap upgrade and far less riskier than what you're dealing with now.
Do you have a feel for what quality level you're dealing with? Are these some older exotics that would definitely be worth the trouble? Or are they torn from a boombox or something like that? It still seems odd--even speakers designed for bi-amping would have some sort of connection terminals or binding posts, and bi-amping isn't required--just optional. Hmmm. Even if that IS the case, what would be "proprietary" about that? It's just wire.
You have to be 100% sure you're wiring everything in parallel. Mix serial and parallel, and you've got a short circuit--you could damage your receiver/amp.
Was this helpful?
Yes
No
Popular Solutions for Pioneer NS-DV88 System
Questions and Unsolved Problems for Pioneer NS-DV88 System
Do you recommend Pioneer NS-DV88 System?
Answer
Answer
while in setup I accidently pressed the progressive scan and now I don't get a picture signal at... (More)
Answer
how do I hook up my PS3 to the surround sound with an optical audio cable?
Answer
Hi, I have a Pioneer XV DV580. It displays an OC ERROR 1 message then shuts down. It was fine for... (More)
Answer
the subwoofer does not work anymore. We;ve been told that it is not the subwoofer self, but that... (More)
Answer
Could you please let me know how to connect the wireless speakers of the above product with picture... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pioneer NS-DV88 System:
Top Home Theater System Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Home Theater System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
