Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Chamberlain garage door opener unit-is it compatible with craftsman keypad?
We have a Chamberlain garage door opener and a craftsman keypad outside the door. Is this keypad compatible? We have a third garage door that still has the original Craftsman garage door opener also-is there a way to program the old garage door openers (Craftsman) with the Chamberlain garage door opener unit, or do I need to buy extra openers (we have several teenage drivers!)Thanks,
Linda
  • 1 more comment
  • dcarroll40 Mar 15, 2009
    I just installed a new Chamberlain garage door opener, but none of my old remote control openers will work, and even when i try to program them using the smart button on the opener, nothing happens. The old remotes are for the openers that I originally installed about 10 years ago. Will they not work with my new opener?
  • grandjean Apr 23, 2009
    I have a similar problem with a twist. I have a Chamberlain wireless keypad which I purchased about 2 years ago. I just recently purchased a Genie garage door opener and wondering if my older keypad will work with the new Genie opener or if I will have to buy a new one. I can't test the keypad vs. the opener until it's installed. If it doesn't work then it would have been a better deal for me just to buy a garage door opener with a keypad included.
  • bobcayman May 11, 2010
    Describe your Problem:
    Craftsman 1/2 hp opener with safty sensor.
    I replaced the drive/worm gears, before the replacement everything worked, after replacement, with a no load condition the trolly will travel about 12" toward the down position and stop and return to the up position making contact with the up contact. The status LED flashes 5 times. The safty sensor green LED are on bright. I swopped out the RPM board, the safty sensors and the logic board, and I have reversed the polarity of the safty sensors with no luck
    Novelist:
  • 91 Answers
Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
Posted on Mar 04, 2009
    Problem Solver:
  • 12 Answers
Chamberlain makes Craftsman so yes, they are the same. Depending on what color the button is on the opener will determine which remote can be used. I suggest using Liftmasters universal remote control and you wont have to worry about this anymore.
Posted on May 19, 2009
    Sniper:
  • 98 Answers
There are 4 diffrent remote/keyless technologies with Chamberlain/Craftsman most likelythe old remotes will not work with your new operator. But you can try to clear out the codes in the operator (push and hold the learn code button for about 20 seconds) then try programming the old remotes.
Posted on Jan 03, 2009
Is liftmaster control compatible with sear-craftman 139-53635SRT model?
Liftmaster and Craftsman are both made by Chamberlain Mfg. Co. Some controls are compatible and some are not the same as some Craftsman controls are compatible with that model number and some are not. The Liftmaster/Chamberlain control that works with that model opener is 81LM.
Jul 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have a new craftsman garage door opener and a new chamberlain keyless entry pad. i cannot get the keyless entry pad to work
As you may know by now there are keypads and then there are keypads. They must be made to work together as there are some that are not compatible. Posting your model numbers might help a little.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wall unit of garage door opener keeps flashing green. I believe it may be in the lock mode. Cannot open door from there, but outside keypad works.
IF THE KEYPAD AND REMOTES WORK IT IS NOT IN LOCK MODE.
DO YOU HAVE THE POLARITY BACKWARDS???
IS IT FLASHING A FAULT CODE???
Jun 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: outside keypad will not open garage door at all bu...
The inside button is hard wired. The keypad is a small radio transmitter. If the battery in the keypad is good and it doesn't work when you put in the code it has probably just quit.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: I cannot reprogram the keypad outside the garage....
Make sure the battery is good and then locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this button and then walk over to the keypad and key in a 4 digit code and press enter.
May 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you program a craftsman keypad remote model no. 139.53776 for a chamberlain garage door opener?
Press and immediately release the smart/learn button on the back of the opener and then walk over and key in your 4 digit PIN and press enter.
If this doesn't work the 2 units are not compatible.
Oct 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Change the code on a garage door transmitter?
There is a "learn" button on the garage door opener unit itself that you press before entering a code on the outside transmitter. This allows the receiver to learn a new code. The button is on the rear end of the housing near the terminals where the inside operation pushbutton connects.
Here's a link to programming instructions for a compatible unit by another manufacturer:
http://www.usdoorcontrol.com/instructions/liftmaster/keypads-66LM.pdf
Nov 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keypad outside not working Properly
Have you replaced the battery in your keypad? That should take care of the trick.
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
4,940 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
