Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Output tray hi my printer tells me to open output tray when the tray is already open
  • Anonymous Jan 21, 2009
    I have the same problem. The Output Tray IS Opened
2 Suggested Answers
  • 13 Answers
SOURCE: printing
Possible firmware fault, if your not afraid of using a screwdriver in your printer remove in the inside top cover and check that the little optical sensor and gate are functioning properly! but as its working in the other 2 modes it would suggest its more likely to be a firmware fault so try resetting it or a firmwear upgrade from website! hope this helps
Posted on Oct 23, 2008
My hp 3510e says "open output tray". When it is already open.
It might be saying open it and look for a jammed document.
Some printers say open a cover and close it to reset the logic board.
Sep 10, 2013 | HP Deskjet 3510 e-All-in-One Printer
Error 1250
look for a small sensor on you right hand side. it tell the m/c if it is open or close. it migit be stuck.
Nov 04, 2011 | Canon Pixma iP4500 InkJet Printer
Canon printer mx328 is when i scan it display ''the paper output tray'' what mean and how to clean it. Please help.
Hi
If the Paper Output Tray is closed, open it. The machine resumes scanning.If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
Cheer
Jul 12, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
IP6000D When I go to print it kleeps telling me that Paper output tray is closed. Open paper output tray. I've tried many locations but can't get the message to go away or to print,
Hi
Have a look at the output tray they might be a little switch there that is not returning out when the tray is down, it cloud be sticking, I think it on the front on right side of that lid that comes down,
All The Best: Pineworks
Jan 23, 2010 | Office Equipment & Supplies
My printer always displays an alarm and asks me to open the paper output tray when it's already open. How do I fix this?
turn the printer off. then take the paper out. make sure all doors are closed and all trays are in. put the paper back in the machine. then turn the printer back on and see if the machine is reset.
Jul 31, 2009 | Canon MX310 Office All-In-One Printer
Print
Hi
Try to uninstall and reinstall driver. and make sure when you are printing from computer the printer is set to copy mode.
Hope this helps
Sep 06, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Photo tray output problem
I fixed it just now and easiest, following the step below:
1) Can you see the blue thing between the paper tray and the printing tray? That's the Output Tray! Just press it back in as much as u could
(but don't break it). Then you trying print (testing), they might have a paper jam but its normal. After the jam, they will tell to dismantle the jammed paper at the back.
2) Shut down (or restart) your printer (unplug the power switch or it won't work). Plug it in again and then just simply its done!
3) If it won't work, repeat the previous step again... Good Luck ;)
Jul 29, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer door open message
Apparently a solution has already been posted here: http://www.fixya.com/support/t345435-ip4300canon_printer
The author provides instructions on opening the printer and gluing the sensor into the "open" position (assuming that the sensor still works).
Apr 01, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
