Question about Gateway Computers & Internet
I'm having trouble acquiring an ip address for gateway notebook
I had to bring my computer to an expert, they have to re configure the hard drive because of symantix
Thanks
Posted on Oct 02, 2008
Acquiring network address ip
This depends on the address you are looking for. The typical address for the adapter is as follows: IP 192.168.1.100 Sub mask 255.255.255.0 Default gateway 192.168.1.1
Oct 15, 2013 | TP-LINK TL-WN321G (812930011748) Wireless...
Cannot acquire network address
what is the model of your router? it would be helpful. you must have the correct ip address and the correct default gateway address. for example, if your router is a Thompson, then your ip must be 192.168.1.1 until 253. and the default gateway 192.168.1.254. you can choose also to automatically detect settings, so you won't have similar problems.
Nov 22, 2012 | ASUS Eee PC 1000HE Netbook
Hi there, Mine is a wifi problem.. at home or at a couple of other places I've tried, my Aspire One connects no probs. At work, it constantly tries 'Acquiring Network Address', and on going...
Plug LAN cables or turn ON Wifi.
Enter Run command or type cmd.
on the command prompt screen ( black it is ) type:
ipconfig /release
enter
next type:
ipconfig /renew
enter
type exit
NOTE: if the problems still remains,which means the router use a STATIC ip eg.192.168.1.5
( CONFIG INTERNET PROTOCOL TCP/IP = ip address : 192.168.1.5 subnet mask :255.255.255.0 default gateway : 192.168.0.8 )
akee_akee@live.com
Aug 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
I AM GETTING A MESSAGE 'ACQUIRING NETWORK ADDRESS' MESSAGE, IT SAYS I AM CONNECTING BUT NO ACTUAL INTERNET
If you are using Windows 7, this can happen. If you own the network, and know the address range, disable Automatic IP on the machine, and give it a static IP address. Make sure you indicate the gateway and DNS server addresses as well.
Feb 14, 2011 | NetGear WGR614 Wireless Router
Will not acquire an ip address on a working
do you have static IP ? if so you would need to enter them by hand in to the internet connection in XP
Jul 23, 2010 | Acer Aspire 3050-1733 Notebook
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
UVERSE 2WIRE 802.1 LAPTOP ADAPTER
Try to acquire an address from the router by performing a ipconfig /release command, then ipconfig /renew at the command line. If that doesn't work then you may have to manually enter IP address and DNS address and Default Gateway address in the IP Properties page of your adapter. Could be your present address is using APIPA or Windoze Automatic Private IP Address of 169.254.x.x
Jun 24, 2008 | Computers & Internet
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Cannot connect to the internet via the Wireless router.
contact ur service priovider they will provide u  ur ip address and default gateway as well as dns server address
After getting ur ip
go to network connection > wireless network connection > properties > scroll down for internet protocol  and double click on it > click on use  the following ip and then enter the ip address and default gateway with dsn server provided  by ur service provider > click ok
now u  r done and u can connect 2 the wireless network
Mar 01, 2008 | D-Link DSL-G604T Wireless Router
Laptop can not connect to router
If you care to try, manually enter IP settings in your laptop as follows:
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
DNS - whatever your ISP is using
In your Internet Explorer >
Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 23, 2007 | Linksys WRT300N Wireless Router
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
