Question about HP Deskjet 6940 InkJet Printer
Blac Spots on right side of page
Every time I print something it comes out with black semared across the right side of the page. The rest of the page prints correctly. What could this be?
  • 2 more comments
  • aparcell Oct 01, 2008
    Every time I print something it comes out with black smeared across the right side of the page. The rest of the page prints correctly. What could this be?
    That did not help the problem it is still doing it. I have tried cleaning the cartridges and replacing the cartridges butit still comes out looking like the example I have attached.
    As you can see the left side to the middle is fine, but most of the right side is covered in black ink. I have also tride to realign the cartridges.
  • jane712 Oct 30, 2008
    We opened up the printer as much as possible, cleaned it - there was a LOT of ink. There is a sponge in there that is soaked with ink but we don't know if that is the source of the problem.
    We're ready to give up and buy a new printer.
    HELP!
  • Anonymous Mar 28, 2014
    there are blakish shade coming on the right side of paper while printing
  • 4,889 Answers
Try changing the paper height.
Lift cover, lever is to the right.
Posted on Oct 01, 2008
    Sergeant:
  • 208 Answers
This generally happens when,
The paper is mismatched to the paper setting for the printer.
For example, if you are using high-quality photo paper, set the printer's output for that paper; do not use the plain paper setting.
Post your response about how things turned up and i can help you up from there.....
Black spots on each page
A laser printer has its rollers (which I believe you said you cleaned...very important) and the cartridge you put in the printer has rollers too! Carefully check them and the wiper on the cartridge. If all of those things are clean, then you should get clean copy!
Jan 11, 2013 | Dell 3130cn Color Laser Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Printer sqeaks loudly when printing. Also there
Sqeaks are hard to fix over the computer but if the black spots are random change the toner cartridge. If they are 3 or 4 to the page change the drum.
Feb 04, 2010 | Brother HL 2140 Laser Printer
Spots along left side of page. On every printed page there are black spots along left side.
something on the fuser... is it the same distance from each spot every time?... then something is on the fuser roller, so it gets fused every time it rolls over that spot. thats my guess
Sep 08, 2009 | Samsung Office Equipment & Supplies
Hp 3310 all-in-one injet spilling black inside unit
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 07, 2009 | HP Photosmart 3310 All-In-One InkJet...
Vertical line and five spots in every sheet of paper I print
Thats on the drum, time for a new cartridge.  The equial distance of the marks on the right side of the page point to the drum  which I presume is built into the toner cartidge.
May 30, 2009 | HP LaserJet 1012 Printer
How to clean Lexmark Z1320 printer.
hi..
You can clean the cartridge using the following steps:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
try out..
Apr 23, 2009 | Lexmark Z1320 InkJet Printer
Small group of spots repeating on page
Have you tried contacting Okidata, 2000 Bishops Gate Blvd.,Mount Laurel, N.J. 08054-4620 Phone 1-800-OKI-DATA(654-3282) or visit www.okidata.com I have a similar problem with my OKIPAGE 10e. 1 inch wide black line, 2 inches from right hand side of page from top to bottom of 8 1/2 x 11 pages. I also cleaned black dust off green roller. Problem continues. Conclusion: I'm not an expert, but I think your wiping, checking, and cleaning, is a waste of time. I think your problem, and mine, is probably not a hardware problem, although I removed my black toner cartridge out of curiosity and perhaps re-installed it incorrectly. My guess is it's some sort of electronic problem, such as programming error, or software problem.
Aug 24, 2007 | OKI B4350n Laser Printer
HP Deskjet 6940 InkJet Printer Logo
132 people viewed this question
Seeker5211
Seeker5211
