Question about Pioneer DEH-P690UB CD Player
Pioneer Supertuner IIID
I forgot how to set the clock on this radio, can you help......................please
  • 1 more comment
  • Anonymous Oct 18, 2008
    helpppp
  • rocking mom Nov 13, 2008
    yep. please help!
  • Kevin Cox May 19, 2009
    the source button just turns on to the AUX on and off with out turn the clock to program mode anyone know of any other way to program the clock?
  • 3 Answers
To change the clock on this Pioneer stereo try this.
1. Press and HOLD the source button till the radio shuts off. Release the button.
2. Press and HOLD the source button again for about 5 seconds until the hour indicator on the clock begins flashing.
3. Press the UP and DOWN buttons to adjust the hours.
4. Press the LEFT or RIGHT arrows to MOVE TO THE MINUTES.
5. Press the UP and DOWN buttons to move the minutes.
6. When complete, press the source button to exit.
Posted on Nov 19, 2008
  • nigeltech Sep 26, 2010
    Worked great, exactly as you stated, thanks
  • 5 Answers
Press and hold the audio button while the stereo is off and the clock is displayed. This will send the clock into set mode. Use the up and down buttons on the right to change the hour. Push the left or right button to go to minutes and use the up and down buttons to change the time. Then push the audio button to make the clock setting stay.
Posted on Oct 27, 2009
I tried all of the solutions posted here and they did not work. Finally I tried pushing and holding the function button, while the stereo was off. This made the clock display blink (ready to set) then used the up and down buttons to set the hour and the right button to change to the minutes and the up and down button to set the minutes. Then push the function button to exit.
Posted on Aug 18, 2010
2. Press and HOLD the source button again for about 5 seconds until the hour indicator on the clock begins flashing. ** I HAD TO KEEP HOLDING THE SOURCE BUTTON WHEN THE HOUR FLASHED I HAD TO HOLD THE UP BUTTON AND THEN LET GO OF THE SOURCE OTHERWISE THE HOUR WOLD STOP FLASHING AND I HAD TO START OVER. EVERY THING ELSE WORKED
Posted on Oct 23, 2009
I had the same trouble..until I found it by mistake.
Turn radio off.. push time button to see the time...then press the volume knob till it say Initializing
Then you can start to change the time with the side arrows.
Posted on Feb 16, 2010
    Problem Solver:
  • 17 Answers
I tried all the buttons and all the sequences suggested --to no avail. Finally, I disconnected the battery negative over night. Upon reconnecting the clock said 12:00. Quickly disconnecting,I waited till 11:59 and reconnected the battery. The clock is now set right, althoug 20 seconds fast. These units tend to forget what their buttons are supposed to do, so that was the only solution I could come up with.
Posted on Jun 12, 2009
Thanks
Posted on May 23, 2009
4 Suggested Answers
shawnsz
  • 64 Answers
SOURCE: pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Posted on Feb 18, 2009
roadcrew
  • 28 Answers
SOURCE: how do you set clock on pioneer wma/mp3 supertuner car tuner
Press function repeatedly until the clock appears in the display. Then use the left and right arrows to select hours or minutes. As you select the segment of the clock the selected segment will blink. Then press the up or down arrow to change the setting accordingly. Press function again to exit the clcok setting
http://caraudio.manualsonline.com/mdownloads/751a22f3-8f11-4855-a9fa-e2ec2056a118.pdf
Posted on Nov 26, 2009
drsinister69
  • 2317 Answers
SOURCE: Set clock on car radio.
Here is a link to the owner's manual for the stereo which will tell you how to set the time:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEH1800.PDF
Posted on May 22, 2010
Testimonial: "Feedback was perfect. It solved my problem and answered even more as I read the manual. Thanks for the help. George Haggerty Jr."
How do I set the clock on pioneer DEH-3300UB supertuner
Page 7 of this manual tells how to turn it on or off. I assume you hold down the clock button until it blinks and then use the up down etc, to adjust it. http://www.pioneerusa.com/StaticFiles/Manuals/Car/DEH-3300UB_OwnersManual0902.pdf
hope this helps you
Jun 27, 2012 | Pioneer Car Audio & Video
Unable to set clock on pioneer super tuner IIID - tried holding down clock button but time doesn't flash. Your assistance will be appreciated thank you
To set up the clock...
Turn radio off.
Hide clock face.
Press and hold a few seconds “clock button” to bring clock face up.
Press and hold “power on button” till clock starts to blink.
The 4 buttons in a cluster on the right under audio, move the hours and minutes.
press power when done.
I hope this helps
Please rate accordingly
Thank you
Computerrep
Apr 27, 2008 | Car Audio & Video
May 22, 2010 | Pioneer DEH-1800 CD Player
How do you set clock on pioneer wma/mp3 supertuner car tuner
Nov 26, 2009 | Pioneer DEH-P6800MP CD Player
I have a Y-cable (dual RCA plugs one end and
you have a stereo rca plug set to a mono audio plug.
you need a stereo rca plug set to a stereo audio plug
Oct 07, 2009 | Pioneer DEH-P690UB CD Player
How do I set the clock for my super tuner IIID/
What is the model number of the supertuner III?
Jun 12, 2009 | Pioneer Car Audio & Video
SETTING THE CLOCK
I found a manual for my super tuner at http://audio.manualsonline.com/manuals/mfg/pioneer/pioneer_cd_player_product_list.html
No tricks, there's an offer but click skip and get your manual.
May 29, 2009 | Pioneer KEH-P2030 Cassette Player
Setting clock radio
Press and hold down the "clock" button. You should see your time start flashing. Normally you set the time with the volume or channel control. Check which control lets the selector jump from "hou" to "minute and set the minutes. To exit setting menu, depress "clock" button again
Apr 28, 2009 | Car Audio & Video
Pioneer DEH-P690UB CD Player Logo
8,837 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
