Question about Sony DCR-HC32E DV Digital Camcorder
Tapes will not play
Camcorder will power on, fast forward and rewind okay, but when PLAY is pressed, only a blue screen appears in the viewer.
The tape counter at the top right is all dashes " -- -- -- ".
Likewise, we can hit RECORD, and the images appear in the viewfinder, but when we rewind to play, only the blue screen appears.
We tried resetting the camera per Sony's online instructions, but no help. They suggested repair service for this problem.
Problem with the heads?? Would cleaning do the trick??
  • 10,594 Answers
Video head is dirty / clogged. Use good quality Mini DV Head Cleaning cassette.
Posted on Oct 01, 2008
Wont play my tapes will rewind and fast forward but they appear as blank tapes after using a tape that was eaten by my last video camera, do you think its something to do with my video head or whatever...
There might have been some sort of residue on the "bad tape" that you played in this camcorder. If you are only getting a blue screen when trying to play back your tapes now, you should try a head cleaning tape. Play the cleaning tape for 5 to 10 seconds and then try your tape again. If it is not all better, repeat this process (only in intervals of 5 to 10 seconds at a time). A head cleaning tape is a little more abrasive than your regular tapes. This will probably do the trick for you. Sony makes an excellent miniDV Head Cleaner. If you do not have one, your local camera shop may or you can find them online reasonably priced.
Hope this has helped you.
www.austintelstarservices.com
Oct 04, 2010 | Sony DCR-HC52E Mini DV Camcorder
My DVM70 will not play back the tapes. I can record and the screen looks like it is recording just fine, everything looks normal. When I go to play the tapes back on the camcorder the lcd screen is blue...
ES MUY POSIBLE QUE EL CABEZA L DE VIDEO SE ENCUENTRE
SUCIO LO IDEAL ES USAR UNA CINTA LIMPIACABEZALES O USAR UN SPRAY DE LIMPIEZA DE USO ELECTRONICO (DE LOS QUE NO DEJAN RESIDUOS OLEOSOS) ,APLICANDO PEQUEñOS CHORROS SOBRE LAS GAPS DEL CABEZAL ROTATORIO , ESPERAR ALGUNOS MINUTOS Y CARGAR EN LO POSIBLE OTRA
CINTA EN PLAYBACK ,TAMBIEN SE PODRIAN LIMPIAR LOS CABEZALES AVANZANDO Y RETROCEDIENDO RAPIDO UNA CINTA
Oct 02, 2009 | JVC GR-DVM70 Mini DV Digital Camcorder
We can see the image in fast forward or rewind but and no audio
Many parts are still available on these camcorders however if it needs a video head for example, and it's not avaiable it may be a better idea to get another 8mm camcorder off ebay, or maybe a pawn shop. just test them with a new blank tape first before putting your family tapes in.
Jul 21, 2009 | Sony Handycam CCD-TRV308 Camcorder
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
Apr 18, 2009 | Televison & Video
Playback
when I plug in the RPU DC cord from my camera to the input on my tv I get nothing. Is my input jack bad or what. Also, if I tried the s video jack from the camera to the tv, would that work??? I don't know what the AV out jack is for I don't have a cord for that
Nov 12, 2008 | Sony Handycam CCD-TRV308 Camcorder
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Panasonic Mini DV Camcorder
Take the tape out to keep it safe, then remove the battery for 24 hours.
Apr 16, 2017 | Panasonic Palmcorder PV-GS15 Mini DV...
I am having trouble playing a Hi-8 tape in my sony camcorder DCR-trv250
Looks like you have a blank area in the Tape. Try Fast forward and you will get again MM:SS:SS.
Mar 25, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony DCR-HC32E DV Digital Camcorder Logo
156 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
