Question about Whirlpool Duet GHW9150P Front Load Washer
F05 error flashing on my duet washer
Two to three minutes into the wash cycle, it beeps and begins flashing F 05. Cancelled and restarted several times, unplugged overnight, reset breaker - none have worked.
  • 5,911 Answers
"F05" is a Temperature Sensor Error. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Since you've already attempted to reset the washer by leaving it unplugged over night, I'm assuming the problem is genuine and not just a glitch. More commonly, the heat sensor connector comes loose. The link explains how to check. I hope you find this information helpful. Let me know if you still require assistance.
Posted on Oct 04, 2008
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
My washer is giving me a code of F 05 right at the beginning of the cycle. The machine beeps, and the cycle stops. What is the problem?
"F05" is an NTC Heater Sensor error. The following link explains:
http://www.fixya.com/support/r3608650-f24_error_code
This error code may be attributed to a heat sensor that has come loose and may not necessarily be an indication of a failed component.
If you do require a replacement sensor, replacement parts may be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed also inlcude helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. Prices will vary, so shop and compare.
If you require additional troubleshooting advice, please post back and let me know. I hope this helps you
Apr 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Starts cycle the about 3 minutes into it 05 then f starts flashing and beeping
Whirlpool 'F05' decodes as 'NTC failure' - really helpful! NTC stands for Negative Temperature Coefficient (thermistor) or, in our language, it's the bit that measures the water temperature ;-0)
I have heard that pouring a few kettles of boiling water into the empty drum and leaving for 10 minutes can sometimes kick it back into life. It's worth a try anyway, otherwise it's a service call I'm afraid ;-0(
Sorry and good luck,
John C
Mar 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer display code F05 what is this code?
the f5 error code is to do with the water inlet valve not working it will need replacing in the mean time try connecting the cold water to the hot select hot wash and see if the water flows into the machine
Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Two of the baffles broke replaced them now getting a code f05 and washer beeps and wont finish wash cycle
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
Above is your service manual, look in the area of the NTC sensor,it needs to be replaced, the service manual will show you how.
You need to replace the ntc sensor, most likely.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Motor error with out error code.
use tech sheet to follow test routine. C:05 is Heater test. some steps take time. during normal operation if timer display flashes, may be indication of standby/pause. Door lock sw may be bad(intermittant)
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
F-05 flashes
The following link expains the "F05" error code:
Check to see if the connector is still plugged into the heat sensor, first. I have seen where the connector has come loose and caused this error code. If not, take the resistance readings as recommended. I hope this helps you.
Jul 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
333 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
