It won't print. the paper just goes right through. It did say offline, I think I need to reset it like it was new
  • 158 Answers
Yes its your printer problem or check your printer connection if you have your printer warranty then send it to printer service center
Posted on Oct 01, 2008
Printer won't work says it is paused
Check your settings , & unpause it !
Mar 17, 2015 | Office Equipment & Supplies
Printer won't print. I had to move the desk and everything was unplugged and now it won't print. It is on, checked as default, on-line, I think it may be the port.
  1. Background
    • HP provides details of the problem on its website. The problem usually occur on PC laptops or when printing across a network. HP offers several fixes for the problem.
    Software
    • First, check your Windows print queue and ensure the printer is not set as "Paused" or "Working Offline." This can often clear the problem and resume your printing.
    Resolution
    • The problem can also be caused by printer driver issues. Try uninstalling and reinstalling the printer driver. Connecting your printer directly to your computer using a parallel cable may solve the problem, but this may not be practical in all cases as many modern laptop computers do not have a parallel port.
Instructions
    • 1 "Power Cycle" Your printer. Shut down the printer, unplug the power cord from the socket, give it 5 minutes, plug it in again and turn it back on. Try to print.
    • 2 If the printer still won't process a job, shut down and restart your computer.
    • 3 Check your printer cable connections to the computer.
    • 4 Check the printer for any paper jams, check the trays, and also pull out the toner cartridge and/or remove any paper jam, if you find one. Put the cartridge back in. Then try to print.
    • 5 If after completing the steps above, the printer is still not working, click "Start," then "Settings," click "Printers," and the printer folder will open. Make sure your HP LaserJet 5 is selected as the default printer.
    • 6 Double-click your printer, and delete everything from the print queue, canceling all the print jobs. Close out the queue.
    • 7 Right-click on your printer icon and make sure it's not offline. If it is, then click "use this printer online."
    • 8 Right-click your printer, and click properties. Make sure the right port is selected for your LaserJet 5 Printer. If you are using a parallel cable, you are most likely using an LPT port; if USB, then look for a USB connection in the list. If the port connection is correct, try to print again.
    • 9 It's still not printing? Click "Start," then "Control Panel." Double-click "Programs and Features" or "add or remove programs," uninstall your Laserjet printer software, and restart your computer.
    • 10 Insert your Laserjet software and driver disk. Proceed to reinstall your printer software and drivers. Then test the printer again. If it is still not working, you probably will have to seek professional assistance.
Jan 20, 2013 | HP LaserJet 1012 Printer
Won;t print keeps saying offline
Hi
Try disconnecting the printer completely from power and from the PC.
Reboot the PC.
Connect everything again.
Clear any print queues.
Check for paper jams on the printer.
Now try printing.
Feb 23, 2012 | Canon Pixma MX420 All-In-One Printer
HP LASERJET P1606DN goes to offline
Happened on our print server this morning for the first time. We have 4 of 1606dn in our organization. Reset the print spooler and that brought it out of offline mode
Jan 09, 2012 | HEWLETT-PACKARD LASERJET PRO P1606DN...
After every page I print, the green light goes out, and I have to press online to get it to continue printing.
Thats ..paper size mismatch, check the paper size settings of your printer in printer properties is the same as what document or document program is set to under page size of the document you wish to print, if these dont match the printer goes offline so you can put in what it's been told is the right size paper or press online to force it to print regardless...so in your case check paper size in both locations and you should be right, there are other things but 99% of the time..thats ya baby;)
Cheers
Nov 15, 2009 | OKI B4600 Printer
Wont print
Right click on the printer deselect the use printer offline
Mar 08, 2009 | HP DeskJet F380 All-In-One Printer
Tally 2280+. While printing, goes offline and displays paperjam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 29, 2008 | TallyGenicom 2280 Matrix Printer
HP Printer D7260 Printer error
i do not have areason for why the printer continuously goes offline but there is a way to put it temporarily back online. Go to printers in the control panel. right click on d7260 and click on use printer online. This only seems to work for one or two docs before you have to repeat the process.
Nov 16, 2008 | HP Photosmart D7260 Printer
41 people viewed this question
jasbo
jasbo
