Question about Indesit W 123 Front Load Washer
It's aWIA121 front loader- Indesit
I have had the PCB replaced before under warranty, now that'a expired and think it needs replacing again as red LED door light flashes all the time. I turn it off at the mains now when not using! It runs through the washing cycle as normal, so could I just leave it? I cleaned out filter as machine getting a bit wiffy. Any suggestions welcome....
    Problem Solver:
  • 5 Answers
Its just a problem with one of the components on the control board - it wont do any harm to the machine, or affect the wash so I wouldn't worry about it
Posted on Nov 03, 2008
Indesit washing machine pumnp burnt out, replaced it but it still won't pump or spin. Does it need a new programmer or can the programmer be fixed?
You're absolutely right. If you look at the wiring diagram on the machine it is clear that the drain pump is powered by triac on PCB (part code C00270972).
I think it is definitely safer and probably cheaper to replace than to repair the PCB.
It is always a good practice to visually inspect PCBs that there are no visible defects such burnt out elements, etc. before replacing. Sometimes the reason for burnout PCB may be on a completely different side.
25580311-2cx31aa5jn1eijqkorrs11s2-4-2.jpg Dado
Mar 16, 2015 | Indesit Washing Machines
I have an indesit wia 101 front loader washing machine. At the moment it will not drain or spin & the red light flashes really quickly
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Indesit W 123 Front Load Washer
It flashes f o7 on my wie 127
hi sir, It seems that a common error code on Indesit washing machines is error code 7. This code can show itself as F 007 or with washing machines that have a rotating control dial the door lock light can flash in cycles of seven times.
This error code usually means, “heater relay stuck”.
The heater is switched on via a relay built into the main PCB. This relay is known to get jammed causing error code 7. In my experience this has usually meant a new PCB needed fitting and as the PCB comes without the main processor EEPROM chip one of those is needed also.
This repair is going to be expensive. I have heard anecdotally of engineers freeing off the jammed relay by giving it a firm tap. However, I would not expect such a repair to last as the chances are the relay would just get stuck again later on.
If a washing machine is still under the five-year parts warranty it would be cheaper to let the manufacture fit these parts but although the parts would be free the labour is going to be about £90.
kindly rate me..
thanks for using fixya..
Feb 12, 2010 | Indesit Washing Machines
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Tv won't stay on
Good Day,
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 16 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Indesit WIA 121 washing machine, front loader. The door lock led is continuessly flashing red even when the programme has stopped and the door is opened. I have to switch off at the main plug. Machine is...
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Apr 21, 2008 | Washing Machines
Indesit washing machine, wil103
from the looks of it, this is called an f12 lights 1&2, communication error
which seems to be quite common. I've got the same problem.
If there's nothing in your filter, it could be the pcb (apparently, according to the research I've done so far).
Quite expensive apparently (£200?), but these machines don't seem very reliable, lots of people on the web having problems.
Dec 19, 2007 | Washing Machines
Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Nov 07, 2007 | Washing Machines
How do I fit a new belt on my Indesit Wil 113 washing machine?
I think its a 'front Loader'? Take the back panel off, to expose the main drive belt & pulley. When fitting the new belt it needs stretching by first putting it around the motor drive shaft & easing on to the main pulley whilst gradually rotatng the pulley. You need to finish up with the belt in the centre of both of the pulleys if possible
Oct 31, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
55 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
