Question about Maytag Atlantis MAV6000 Top Load Washer
Cannot disconnect cold water hose
My cold water hose is clogged at the filter screen. The problem is that the hose fittings are recessed into the back of the machine. How do I get the hose off to clean the screen?
    Genius:
  • 1,122 Answers
You need a small pair of channel locks,i use them all the time on this kind of remova,let me know how it goes-mikel
Posted on Oct 01, 2008
Hotpoint AQGMD149
First check the cold water supply filter screen to be sure it is not clogged with debris. Disconnect the cold water line, and there should be a filter screen inside the hose connector. Clean it with a stiff toothbrush.
Jun 22, 2014 | Washing Machines
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
My washer machine stopped working and now have no cold water in machine
first thing to check is for a clogged filter screen at the cold water connection on the machine. the screen will often fill up with crud and create a blockage. Clean and reinstall or replace the screen for both hoses.
remember to shut off the water before you disconnect the hose, and while you have it off, try running some water into a bucket to rinse other grit out of the line before reconnectind and to confirm that water is getting to the machine.
Jul 07, 2013 | Home
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
Cold water trickles into the tub while it is being filled up
The hot and cold water supply hoses that connect the washer from the water supply faucets on the wall to the water connections on the back of the clothes washer usually have filter / sediment screens within there connection fittings at the end of the hoses, these will collect dirt,sand, calcium deposits, etc.,when they trap enough of these materials they will plug up and restrict the flow of water into the clothes washer. Turn off the water faucets at the wall, and you should do this for both hot and cold hoses, disconnect the hoses from the washer and the water faucets, look into the hose ends and pull out the screens and clean them out by running water and what ever you can use to clean them completely!!!!!
Now look inside the water connections on the back of the clothes washer,where you screw the hoses on the washer, and check to see if there are filter screens in there, if there is, remove them and clean out completely also, then reverse the removal process and reconnect the hoses, makeing sure to connect the hot and cold hoses to the right connection on the back of the clothes washer!!
Try filling the washer with water to see if you have corrected the problem.
Make sure hot and cold hoses are correct on the back of the washer!!!!
GOOD LUCK !!!!!!
Aug 03, 2010 | Whirlpool Washing Machines
Cold water fills very slowly
Turn off the water, remove the cold water hose at the back of the washer ... inside you will find a hose washer with a screen on it - remove and replace it. I believe you will discover the screen is clogged. While you have the hose disconnected, run some water into a bucket from the hose to clean it as well.
Jun 19, 2010 | Kenmore 24032\24036 Top Load Washer
Cold water fill is super slow
Do this:
1. Un-plug the washing machine
2. Shut off the cold water supply valve to the machine and then disconnect the cold water hose at the machine. Place a small container under the fitting when you do this to catch the water that will probably leak out.
3. Place the disconnected end of the hose in a bucket or the sink if you have one and SLOWLY turn the cold water back on. make sure the water pressure coming out of the hose is good. If so, the problem isn't there. Turn the valve back off.
4. Set the disconnected hose aside. Take a good look at the connection on the machine (where you disconnected the hose). There should be an inlet screen. It's common for these screens to plug up once in a while, especially if you are on well water. Remove the screen and clean it, being careful to not lose the washer. The screen can be rinsed out in a sink. Look for any other debris that may be in this connection.
5. Re-install the screen, re-install, the hose, turn the water back on slowly, and check for leaks. Plug the machine back in.
6. Try filling the machine again with the washer empty, just in case some muck also comes out so you don't stain your clothes.
7. If it works ok, you're done. If not, then the water fill valve itself may not be working properly and may need to be replaced.
8. A weak electrical connection to the fill valve can also cause this condition, but it's usually the inlet screen.
Good Luck and re-post if you have further questions!
Feb 02, 2010 | Washing Machines
Washer has hot water only,no cold or medium cycle when selected.
Inlet screen in the cold water hose is clogged (check at both ends) or the solenoid valve has failed.
Oct 29, 2009 | Washing Machines
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Atlantis MAV6000 Top Load Washer Logo
106 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
