Question about Microsoft Windows XP Home Edition
DVD drive recognition
One day my DVD drive disappeared. It is no longer on My computer and when I put a CD in nothing happens. i tried uninstalling the secondary IDE Channel and it said New hardware detected but it didn't work i also tried default settings on Bios and checking the drive was enabled.
Please help
  • 158 Answers
Remove your ide cables and power cable and also jumper setting in your dvd drive check it
Posted on Oct 01, 2008
My Cd/DVD burner has disappeared I have tried deleting the upper and lower filters and it still doesn't show up the tray opens the light comes on but it's not usable or found anywhere I have an HP...
Try this:
I have to ask, after deleting the upper & lower filters did you reboot the PC?
If so try this:
Go to:
Start>(right click on Computer)left click on Manage.
Left click on Device Manager
Locate your DVD/CD-Rom drives.
Right Click on the DVD/CD Rom-drive> uninstall Now reboot the PC.
If the drive does not come back in Computer> devices with removeable storage go back to Device Manager (Start>right click computer>Device Manager) to see if you can see DVD/CD Rom-drive.If you dont see the drive in this location then it sounds as if your DVD/CDRom-drive is no longer working and you will have to replace it.
Aug 09, 2012 | Computers & Internet
I have a Sony Vaio VGN-SZ230P. It has a Matshita UJ-842D. It was working fine until today. The drive shows up under 'My Computer' and 'Device Manager' however when I put in a CD or DVD it doesn't do...
Sounds like it is your power supply going. I know this sounds way off base. But I have seen it many times. First this happens with the CD or DVD as they have are lower on the list for power allocation than other devices for power. If this is it next the hard drive will stop responding. This has been my experience in these matters. It might be the drive but I would say 70% chance of power supply.30% chance of drive.
Sep 23, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
DVD CD ROM Problem
CD/DVD Drive Missing In My Computer
1. Go to Control Panel > System > "Click Hardware Tab" > Device Manager > IDE ATA / ATAPI Controllers > Right Click then uninstall
2. Reboot
3. If the problem is still their you will need to remove the upper and lower registry keys. You can do this by following this Microsoft Knowledge base article. http://support.microsoft.com/kb/314060
Sep 21, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Toshiba Satellite P105-s6147 CD/dvd drive some how uninstalled
Registry edits not usually a good idea. System restore is your friend. Some DVD burning apps will change your registry and cause the CD/DVD to disappear. Uninstall the new burning app, or system restore to a time you know it was working.
Jul 24, 2009 | Computers & Internet
Dvd plays initially and then stops
It could be the drivers for CD/DVD.
The best way to troubleshoot this is right click on computer, select manage. A new window will pop up, in that list select device manager.
Look in the list for CD/DVD drives and click on the + sign next to it, when the tree opens right click on the CD/DVD drive and select uninstall, then restart the PC.
This method will hard reset the system and force windows to load the default drivers for the CD/DVD upon restart. Hopefully this should resolve your problem.
If not please post back.
Good luck
Jun 15, 2009 | HP Pavilion DV2740SE Laptop
DVD burner problem
hi DARBAIL!
I have the same unit like you. I Have experienced that the cd/ dvd burner doesn't work because cables might have loosen up. Check the IDE cable if it was connected properly. Try to Check also the burner eg. Nero maybe it was not installed properly. Check the installation settings If it was installed completely. Try to check also the system of your computers may be the Direct X component was not installed.
If you have tune up utilities, Try to Check it properly using the device manager if it was installed in your system.
Lastly, after you have tried all of this but nothing is happening. Your unit CD/ DVD has faulted. Better buy a new one.
Jonags3
Jan 13, 2009 | LG Computers & Internet
Dvd-rom not playing/recognizing dvds but plays cds
Yes your quite right, the solution to the problem is a new writer, although you have to get the same one if it's fitted internally to a notebook. You can update the firmware, thats not a problem, you may be getting confused with bios updates which are a knightmare. I assume you have tried the usual, uninstal and re install of the dvd drive, by uninstalling it in device manager on the cd/dvd drive line and click '+' sign, right click and uninstal, then restart pc to automatically install again. The cd recognition says that the drive capability to read and write dvd has corrupted andfailed, so really the only solution would be a new drive
Apr 28, 2007 | Toshiba SD R6012 (SDR6012-TA) DVD-RW...
Computer doesn't recognise CD drive at all
This may not help, But worth trying. First make sure the eide braid is connected firmly on both end and the power cord is pushed in all the way. if all that is okay do a Google search for lite on they have a website with lots of drivers and firmware upgades. Just need to find yours in the list. Good luck
Jan 06, 2007 | Lite On SOHC-5232K CD-RW/DVD-ROM Burner
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
Microsoft Windows XP Home Edition Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
