Pioneer NS-DV88 System
Problem for Pioneer NS-DV88 System
Sub not working
By kcw573 - usenet poster
I just got a new Yamaha RXV-800 and the Energy Take 5.2 speaker system with the 8.2 subwoofer. The receiver has a sub-out and I have a monster cable connecting the sub. All other speakers work fine but the sub gets nothing but a slight buzz at best. With the receiver power off, I removed the RCA cable to switch cables and the Sub then gave a buzzing sound whenever I touched the open RCA connector. Does this mean that the Sub is bad or the cable shorted? I exchanged the receiver because I thought it was the output jack, but the problem continues with the new receiver too. Any thoughts? Thanks.
Same Problem
Nov 03, 2007
-   all 5 speakers work but the subwoofer doesnt at all there is no buzzing sound at all it just doesnt work. everything is hooked up in the right place. what buttons do i need to push on the remote for the subwoofer to work?-   Liza_09
Nov 03, 2007
-   all of the speakers work and everything is connected where it needs to be but the subwoofer doesnt produce any sound at all, i cant get it to work i dont kno if its that it just doesnt work or if im just not pushing the right buttons on the remote-   Liza_09
Solution #1
posted on May 30, 2006
Somewhat Helpful)
Grant
Rank: Apprentice
Rating: 0%, 0 votes
Check your receiver setup for; subwoofer output level, LFE output level, and speaker size settings. If you select large main speakers your sub will receive less bass. And make sure your use spliter on your sub cable so to have a right and left input into the sub. It really makes a difference.
Good luck
Was this helpful?
Yes
No
Solution #2
posted on Jan 24, 2008
Not Rated)
XMOZZAZX
Rank: Apprentice
Rating: 0%, 0 votes
Excellent Grant! You solved my problem anyways.
Was this helpful?
Yes
No
Solution #3
posted on Oct 12, 2007
Not Rated)
rtek77
Rank: Apprentice
Rating: 0%, 0 votes
the splitter makes no difference, connect the sub pre-out to the left input of the sub and set your speaker size to small, on most yamaha recievers the sub out is turned off when you set the front speakers to large
Was this helpful?
Yes
No
Solution #4
Not Rated)
Bomber
Rank: Apprentice
Rating: 0%, 0 votes
Connect an RCA cable to your sub woofer, turn it on, and touch the RCA plug at the other end of the cable with your finger. If you hear a buzz, the sub woofer is not the porblem, probably just a setting in your receiver.
Was this helpful?
Yes
No
Popular Solutions for Pioneer NS-DV88 System
Questions and Unsolved Problems for Pioneer NS-DV88 System
Do you recommend Pioneer NS-DV88 System?
Answer
Answer
while in setup I accidently pressed the progressive scan and now I don't get a picture signal at... (More)
Answer
how do I hook up my PS3 to the surround sound with an optical audio cable?
Answer
Hi, I have a Pioneer XV DV580. It displays an OC ERROR 1 message then shuts down. It was fine for... (More)
Answer
the subwoofer does not work anymore. We;ve been told that it is not the subwoofer self, but that... (More)
Answer
Could you please let me know how to connect the wireless speakers of the above product with picture... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pioneer NS-DV88 System:
Top Home Theater System Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Home Theater System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
