Question about Pioneer DVR-530H-S DVD Player/HDD Recorder
Pioneer 530H DVD recorder
The remote control has no effect on the recorder, there is a P on the recorder display.
No button on the remote control has any effect on the recorder, like there is no battery in it.
I changed the battery's for new ones.
My email adres is j_erkelens@hotmail.com please help.
  • cnmaclean Dec 09, 2008
    I moved my DVD recorder to another room.
    Now, the remote won't operate the DVD recorder.
    I have confirmed that the remote is still emitting a signal, and I can operate the DVD recorder manually. But the remote has no effect.
    Sergeant:
  • 208 Answers
You said that you have changed the batteries.
While you're checking the batteries, make sure that the contacts for the batteries aren't corroded or bent. You can clean them with a pencil eraser followed by a nail file. If necessary, gently bend them back to their correct position.
Try these too,
  • Go up to the receiver and try changing the channels without using the Remote Control.
  • Refer to the Remote Control setup instructions, and make sure you have the correct codes programmed for your equipment.
  • Make sure nothing is blocking the front of the receiver (e.g., furniture).
  • Make sure you are operating the Remote Control within 20 feet of the receiver.
If all the above doesnt work,
Then
Either the remote or the receptor on the device is not functioning.
1. Use an Infrared Sensor Card to see if the remote is sending a signal.
2. If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
You can visit this site for further support, www.pioneerelectronics.com/PUSA/Support/CarAudioVideo
Hope my info solves your problem,
Thanx for using fixya....
Posted on Oct 01, 2008
My remote is broken and need new, how, please help my!
ebay has a lot used remotes but it will need to be reprogrammed
Aug 27, 2013 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Remote control does not work
Hello
Check the remote control for its infrared emission. If it is found OK, and still your device does not respond to remote control, the infrared sensor inside your device is faulty and should be replaced. Just enter into the following link. You can understand how a remote control can be repaired or cleaned. Do this first.
The remote sensors can be located just behind the infrared sensor window of your device. You have to open your device to access it.
Dec 26, 2011 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Hi we have inherited a Pioneer DVD Recorder DVR -530H. I have no instructions - the foxtel guys has hooked it all up to the TV however I cant work out how to clear all the recordings that are stored on the...
  1. You must be in the Disc Navigator (HDD)
  2. Highlight the title you want to erase.
  3. Select 'Erase' from the command menu panel.
  4. Select 'Yes' to confirm or 'No' to cancel, then press ENTER.
  • You can also Highlight the title you want to erase, press clear on the remote, and press ENTER.
Here is your manual: http://www.pioneer.com.sg/storefront/manual/DVR-530H.pdf
Feb 28, 2011 | Pioneer DVR-3100 DVD DVD Recorder
I have a Pioneer DVR 531H and I get the HDD error message What's the solution Barry
I have a Pioneer DVR 530H and I get the HDD error message and freezes
What's the solution
Aug 20, 2010 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Pioneer DVR-530H-S having erased a recorded program can it be recovered
dear madam,
i have DVR-530H-S my file have erased a recorded program can it be recovered, how to make it... very important for me...
or please call +62 8040-727-69
email : doraprod@yahoo.com
please call me after your post to email
thanks before
joko sudaryanto
Jul 20, 2010 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Pioneer dvd recorder dvr-530H
The EPG is the electronic program guide trying to download TV listings.
http://en.wikipedia.org/wiki/Electronic_program_guide
This is normal for this player. To disable this, you would need to turn off the TV guide function.
Sep 28, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Unlock Pioneer DVR-531H
check ebay - i got a disc for my 530h on there which unlocked it perfectly
Mar 30, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Remote control
I called a Tech @ Panasonic and he told me to point and hold the "OK" button and the number 2 for about 10 seconds. Then I pressed the power button for the DVD recorder and it worked.
Jan 30, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Pioneer DVR-530H-S DVD Player/HDD Recorder Logo
309 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
