Question about Mitsubishi WS-48513 48" Rear Projection Television
Rolling horizontal black bar 1" tall on the tv screen
There is a horizontal rolling black bar about 1" tall that seems to go from bottom to top on the tv screen. resetting the tv seems to help for a while, but the problem reoccurs after about a minute. with the dvd on and all other inputs shut off, the problem is still there.
  • hd72mary Oct 02, 2008
    the rolling black horizontal bar is still there. i exposed the inside of the tv. it is a mitsubishi rear projection 48" hdtv. i kept the tv on and noticed no excess heat. i used compressed air cans and cleaned the inside of the tv. other than the rolling black bar, there are no other issues. this time i removed all inputs from the tv and put my outside antenna on and ended up with the same results. i was going to try and clean the projector lenses, but they are enclosed.
    i have the back off of my tv. could you please tell me or show me where the power board is and where do i obtain the capacitors?
    Guru:
  • 558 Answers
Please purchase the Quick Reference Guide from the Official site of Mitshubishi
Click Here
It is not possible to diagnose it without a hands on investigation. It could be ICs; I am not doubting that, but it must be determined by an actual investigation. Check out the Integrated Circuit (IC) Capacitor and Transistor on both on CRT board.
Regards
Ellin
Posted on Oct 02, 2008
  • 10,594 Answers
Please check bigger capacitor in power supply baord, seems its leaky. You can see some liquid / oil some thing around it or can notice its top is bulged or opened.
  • Shahid Electronics
    Shahid Electronics Oct 02, 2008
    I can give you an idea of bigger capacitors as I don't have specific pictures of this model.
    Below picture shows bigger capacitors.
    Hope this info will help you to locate power capacitors and their value will be approx 1000UF 250V
    Guru:
  • 1,894 Answers
This is a problem with heating of some components of the TV inside it.
i would suggest you to look inside the unit and check for components with high heat
Posted on Oct 01, 2008
  • 2 more comments
  • dewan nafees ahmed Oct 01, 2008
    actually after what time does the unit shut down??
  • dewan nafees ahmed Oct 02, 2008
    attempt to locate the horizontal hold circuit and replace the defective compoents like lekaing capacitors
  • dewan nafees ahmed Oct 03, 2008
    1. Unplug the TV. Avoid as many electronic devices as possible while
    going through this entire process. Observe proper ESD practices.
    2. Unplug cables from TV. If you have more than one input, you might want to mark these, so you're not guessing later.
    3.
    Remove back brown panel from TV (approximately 12 screws). Remove front
    speaker grill. This is attached with plastic "pop-ins". Sitting in
    front of the TV, pull the outside bottom of the grill on each side at
    the same time. The panel should pop out so you can remove it.
    4.
    Remove the front black panel (six or eight screws). BE CAREFUL, reach
    in and untie the wires from the twisties (pictured in previous posts).
    You will need the slack from the wires to pull out the tray. You should
    find yourself untying about 10 twisties.
    6. The three main
    cards are mounted in a tray that can slide out. Remove three-four black
    screws (app. 3” long) from the outside trim that holds down the tray.
    There is a bracket attached (triangle shaped) to the cable connection
    board that also needs to be removed (back of TV).
    7. There
    are two, small black teeth on the front of the tray under the screen.
    Those should be pushed up with the finger. Making sure you don't pull
    any of the wires too tight, work the tray out from the TV. Please go
    slow on this. If you feel some tension, there is a wire you did not
    untie.
    8. Once the tray has slid out enough to do your work,
    Remove the board mounting screws. There were three on the back, two on
    the front, and one in the middle. There is a silver box on the left on
    the card (approx. 5"x1"x4") that the two mounting screws needed to be
    removed.
    9. Remove the bracket (three screws) that press the
    chips to the heat sink. Remove the three screws from the heat sink that
    mount to the board. You should feel the board loose. If it is not, you
    missed a mounting screw.
    10. Pop the white cable connectors
    up by using a small flat screwdriver on the side with a small lip.
    Remove the rest of the jumpers. u will not need to label these, as they
    were unique in size, and/or had unique labeling on them. You may want
    to label them to be safe.
    11. Remove the board and do the
    deed. It is to your
    advantage to find a friend, coworker, neighbor, etc. who is experienced
    with soldering to at least help look over what you do.
    also this must help you
    also this
    thank you
    hope that must help.
    please post back with your results
    thank you
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
I have a Samsung DLP HLN 5065W and recently the TV started to get Horizontal Lines in it with a 2 inch black horizontal line across the TV and the bottom half you could see the picture and the top half...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Samsung HL-R6168W 61" HDTV
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Black bars on hd channels
Press the # on the cable remote to expand the picture. you cable company can help.
Mar 18, 2010 | Mitsubishi WS-55805 55" Rear Projection...
Rolling green horizontal bar from top to bottom,then bottom to top and so on. sometimes rolling fast,sometimes slow and sometimes the green bar stops in the middle of the screen.every once in a while the...
This TV needs a service adjustment done. Looks like a vertical or horizontal IC is failing. I'd go ahead, and shut off until services adjustment is made. Have you unplugged for a few minutes and plugged back in? However, I'd have a service tech look at it.
Oct 25, 2009 | Mitsubishi WS-48513 48" Rear Projection...
Lines on top of screen
Hi and welcome to FixYa,
Initially, sounds like a capacitor at the vertical section about to fail, leaking or blistered. Additionally, have seen some of these models suffers from vertical fault due to a defective capacitor in the power supply section or cold solder.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 03, 2008 | Televison & Video
Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
Jan 11, 2008 | Mitsubishi WD-52725 52". Rear Projection...
White horizontal lines on screen
Replace all electrolitic capacitors on the Proscan pcb.
Dec 11, 2007 | Televison & Video
Rca p52937sg
Hi, your vertical section is beginning to fail, from your description you have a few electrolytic capacitors that are beginning to go bad, the correct term is they are "leaky", the set can be fixed easily by a tech, not so easy for a layperson because you don`t have the service manual or a capacitor analyzer. NOT an expensive fix, tech will have to remove board, unsolder some caps, check them and replace the bad ones, do a little touch up solder work and set is good as new, any questions? feel free to ask away, if not Happy Holidays, BMW Rider
Dec 08, 2007 | RCA P52937 52" Rear Projection Television
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi WS-48513 48" Rear Projection Television Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
