Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 washing machine
Disply reads fo5 and the wash cycle has been interupted
  • thanks_eagle Jan 04, 2009
    I have had the same problem and searched the web for a solution. I came across this website, followed the steps suggested by eagle 338, opened up the machine (turned it upside down for easy access) - not sure if this was the right thing to do ! Anyway I opened up the clips and took out the pump and found half a child's sock and a 50p piece in the pump ! I have now removed the offending items and reinstated the pump. The machine now works again and so far no problem. Tomorrow not only will I not have to buy a new machine (who's going to pay £100 for an engineer to come out ?) but I've got 50p for a chocolate bar !
    Many thanks to eagle 338
  • janbilljamte Feb 20, 2009
    I've got to the back of the machine. Does the 'small panel' at the bottom have a couple of screws securing it? This seems to come off easily and exposes the belt etc. Where is the pump?
    Thanks
  • 4,889 Answers
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Posted on Oct 01, 2008
The solution listed above that its pump clogged up and pressure switch has tripped was correct for f-05! However first thing you should do is remove front strip at the bottom of the washing machine which reveals an access cap for the pump, took 30 seconds to clean out, didnt even need to take the back of at all!
Posted on Jun 06, 2012
Model wf740 aquarius hotpoint is flashing f-05 need a solution.
Posted on Oct 26, 2008
  • dannymaddix Oct 26, 2008
    showing f-05 on model wf740
  • TRACY JONES Sep 21, 2012
    HI I AM GETTING CODE H20, ANY IDEAS,
WF740 Aquarius washing machine keeps going through a Test cycle. Cannot get it to wash?
Turn off the appliance at the mains, hold on & start buttons down then turn back on at mains and hold until dOFF appears should now be back the normal.
Oct 20, 2014 | Hotpoint Washing Machines
Machine stoped half way in to cycle fo5 appeared on display panel
You need to clean the pump filter.
Remove lower rear panel of washer.
Locate and remove large black hose on bottom of drum.
Remove an clean plastic filter inside the hose.
Reassemble and test for leaks.
Jan 23, 2011 | Hotpoint Washing Machines
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WF740 Hotpoint washing machine with bad smell from drum. Tried 95 degree wash but still smells. Door seal slightly blackened but I think smell is from drum too. Any help?
Wash it out with a strong solution of washing soda placed into the drum before you fill the machine
Ps
Run the machine empty through a full hot cycle then run the soda one
The first will soften the deposits and the second should help kill the bacteria that is causing the smell.
Reducing the load so that there is more agitation helps as well
Jul 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
1,451 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
