Question about Cameras
I have a fuji f810.the pop up flash will not pop up.
The problem is the top RH edge of the Flash Assembly becoming stuck under the edge of the top side of the camera case in which it sits. Solution gently prize the flash housing to the left as viewed from the top of the camera case whilst the camera is in the take mode whilst pressing the flash button. When the flash assembly pops up file the RH edge of the flash assembly cover as viewed from the top with a fine swiss file. Take care not to get any filings in the camera. This will totally restore the flash operation to normal.
Posted on Jun 13, 2010
Fuji finepix f810 flash wont pop up when button pressed
hi your camera is kind of getting old but it is still great. some people really like it. personally I like also. however, fuji finepix f810 has little problem like yours due to delicate design. on your flash problem could has two sequence check. first is flash circuit defective or flash tube defective. second is main pcb doesn't work properly with flash function. your local repair shop would charge around $75 to 185. Fuji camera usually charge more than other brand. I am sorry that you know. Good luck with you and best regard.
May 22, 2011 | Fuji FinePix F810 Digital Camera
How do I fix the pop up flash on my fuji finepix s700
fix the pop up flash,,,,select manual M operation,flash donot pop up.
Apr 03, 2010 | Fuji FinePix S700 Digital Camera
Cannot install my finepix f810 onto my computer, correctly.
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free program Picasa ( http://picasa.google.com ).
Feb 04, 2010 | Fuji FinePix F810 Digital Camera
Flash not popping up
This model does not have a manual flash pop up release, so if the flash is not needed, it won't pop up at all. Use the "flash" button on the back of the camera to set: fill, forced, disable, etc. flash settings.
Jul 05, 2009 | Fuji FinePix S700 Digital Camera
Fuji FinePix F810: flash light does not pop up when button is pressed
Hi guys,
I've had the same problem with my f810. I found the solution on a german photography forum:
while pressing the flashbutton with your thumb on the rearside of your camera, push on the body of the camera under the flash on the frontside with your index. try various positions of your index and you'll see: it will open!
neto
Oct 26, 2008 | Fuji Cameras
Fuji s700 my flash is not popping up on auto and my camera is taking all dark pics
The flash on my S700 stopped popping up too. But I made a spring about 3/4 inch in diameter by 3/4 inch high with about 1 3/4 loops. I glued it right under the flash. It works quite well now.
Sep 01, 2008 | Fuji FinePix S700 Digital Camera
Cameras Logo
85 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
