Question about Whirlpool Refrigerators
Have just defrosted a Whirlpool AFB6600. When I've turned it back on the fast freeze button works but if i switch the fast freeze off (even after several hours) the freezer starts to defrost.
    President:
  • 1,462 Answers
Thermostat is faulty - all fast freeze does is to bypass thermostat
Posted on Oct 03, 2008
My Whirlpool Mark Series Model # EB19MK is not cooling or freezing. Compressor is working, fan is working. Does it have reset button?
No reset of that kind. Did you loose cooling gradually over several days? if yes, you may have a problem with the defrost system causing an excessive frost buildup in the freezer section. symptoms would be excessive frost on freezer back wall. Possibly a bad defrost heater. Replace defective part and manually defrost refrigerator before re-starting.
May 24, 2015 | Whirlpool Refrigerators
Refrigerator-freezer won't freeze
I think the fridge is low on gas, or the defroster is on all the time
Mar 24, 2013 | Whirlpool Refrigerators
I have a hotpoint freezer FZS175, the alarm is going off. I've followed the instructions, turned the thermostat to zero, waited, then back to mid-way, pressed the fast freezer button. The freezer
Just had exact same issue with our FZS175 upright Hotpoint freezer - could not reset the alarming state.
Tried defrosting (even though it didn't look like it needed it) but still no change.
Then found the shaft of the little plastic thermostat control knob had sheared off. The only way to tell this has happened is to remove the control panel cover (switch off at mains first of course).
Superglued the broken knob shaft back together, inserting a 1mm steel reinforcing pin (cut from a woodworking panel pin) to prevent it happening again, and all is now well.
I think I am in the wrong profession (British wildlife documentaries)!
British Nature Films Wildlife films of the British countryside
Mar 15, 2012 | Refrigerators
On normal operation my freezer alarm will not stop bleeping.The only way to silence alarm is to switch to Fast Freeze ,however the compressor runs contually ,even after 24hrs and switching back to normal...
Have you cleaned the condenser grill and made sure you have plenty of air flow around the unit? It might also be time to take the food out and completely defrost your freezer! Since you do have an ice build up on your evaporator grill.
Jul 31, 2011 | Whirlpool Freezers
Whirlpool refrigerator type 2255A The problem I
check your defrost timer manually rotate it possible stock up or replace if damage check the resistance of your defrost heater if good the freezing is normal try to adjust it to the next level of adjustment then conduct observation. check also the thermodisc it is connected to sense the ice vulging of your unit that trigger the defrost heater and defrost timer observe unit.
Feb 19, 2011 | Whirlpool Freezers
I have a whirlpool fridge freezer 2 years old.. the fridge was left open over night it wont get cold now even thiough i can hear the gasess in the back is it worth repairing is it a big job
shut down the whole unit and let it FULLY defrost,dry it out and then restart as new,it may take 24 hours to settle down,it will help if you have a "fast freeze" button.(as i live in England im not sure of your model).
Dec 29, 2010 | Whirlpool Refrigerators
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer Problem
The only thing I can think of is your icemaker heater is staying on. When your icemaker goes into a harvest mode, (dumping ice and then re-filling with water) there is a "U" shaped heater (located on the under side of the icemaker) that comes on to release the frozen cubes from the icemaker mold. If this heater is continuously hot, it will cause temperatures in the freezer to rise.
Oct 04, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Refrigerators Logo
183 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
