Question about HP Office Equipment & Supplies
HP Scanjet 4470c need driver for the Mac - HP Office Equipment & Supplies
  • Compumom Oct 01, 2008
    I think I was cut off by an update. Thank you for your reply. I took a look at the HP Scanjet 4470c support page. I read there was no driver for the that model using a Mac OS X 10.5.5.
    I did not go into the site you posted, but will do so to satisfy my curiosity.
    Thanks once again.
    Scholar:
  • 158 Answers
U can download the driver here:
http://www.findmysoft.com/drivers/Hp-scanjet-4400-4470c-scanner-3-14--driver.html
hope this ll help u
good luck:-)
Posted on Oct 01, 2008
Scanjet 4470c. Can't get it to work with Windows 7. Any ideas on a solution or is there a Windows 7 driver out there?
Hi ,
I succeeded to make my Scanjet 4470c run in WIA mode under W7 32-bit Ultimate . Should also work with W7 64-bit .
Make sure driver XP ( yes , XP ) is correctly installed .
Then , download and install FreeKapture ( yes , it's free ) from here : http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Load Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanner works fine in this mode but if you choose HP PrecisionScan Pro , program will freeze .
In any case , no slides or negatives scans possible but the rest works .
Regards .
Dec 13, 2010 | HP Scanjet 4470c Flatbed Scanner
Hi! I need driver for HP 4470c for Windows7 Please Help!
Hi ,
I succeeded to run my Scanjet 4470c under w7 32-bit Ultimate this way :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekature , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
Regards.
Nov 05, 2010 | HP Scanjet 4470c Flatbed Scanner
There is no driver for the scanjet 4470c that works with my Vista system on my Toshiba laptop.
Hi ,
Vista or W7 , it's the same problem : there are no more drivers for Scanjet 4470c .
I find a way though , to make the mine work in WIA mode under W7 32-Bit Ultimate . Should work with Vista too .
Make first sure driver XP ( yes , XP ) is correctly installed .
Now , download and install Freekapture ( it's free ) from :http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
In any case , no slides or negatives scans possible but the rest works . As for the buttons , only power button will respond .
Regards .
Oct 09, 2010 | HP Scanjet 4470c Flatbed Scanner
I need Windows Vista drivers for scanner hp 4470c. The support product of HP does not have it. Thanks
I checked the HP website - probably just like you did. They do not have drivers for the Scanjet 4470c. Looks like time to get a new scanner... You can list the current model on craigslist - maybe someone would be interested in it themselves.
Sep 23, 2010 | HP Scanjet 4470c Flatbed Scanner
Buenos días, Tengo un Imac con sistema Mac OS X 10.6 Snow Leopard y un HP Scanjet 4470c Como podría solucionar el problema que el Scanjet me funcione con el MAC, no hay manera...
Hola usted debe poder utilizar el conductor para MAC OS 9 para trabajar con su sistema que yo han buscado su explorador de los caballos de fuerza en todos los sitios del MAC y los sitios del HP pero ninguno ofrece los conductores para su específicamente, ellos no hace uno hasta ahora sino intenta éste puede trabajar esperanza éste ayuda a apesadumbrado para la mala traducción
Jul 28, 2010 | HP Scanjet 4470c Flatbed Scanner
Need a hp scanjet 4470c driver for os 10.5.8
Production of HP drivers stops at OS 9 .
No more driver available for further OS .
Regards .
Apr 21, 2010 | HP Scanjet 4470c Flatbed Scanner
HP Scanjet 4470c compatible with Mac OS X 10.6.1
You will not find drivers for this old scanner. Sorry but this scanner is not compatible with Tiger, Leopard, or Snow Leopard, and HP offers no drivers other than for OSx 8.0 & 9.0 which are 10 years old. Time to purchase a new scanner.
Nov 10, 2009 | HP Scanjet 4470c Flatbed Scanner
Driver for scanjet 4470c on Vista
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Jan 26, 2009 | HP Scanjet 4470c Flatbed Scanner
4470c
If you can get the software on your computer, right click properties and check run in XP mode
Aug 28, 2008 | HP Scanjet 4470c Flatbed Scanner
Driver update for Mac 10.xx for HP 4470c flatbed scanner
I'm having the same problem, it's £10 from Hp's website, unless anyone out there can get it for free?
Nov 30, 2007 | HP Scanjet 4470c Flatbed Scanner
157 people viewed this question
Seeker5211
Seeker5211
