Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Belt broke, can't get bottom off
I have a Kenmore 2331303 canister vac with a powerhead model #53313303. The belt broke I can't get the bottom off.
Thank You so much for your help!!
  • extracabpu Dec 08, 2008
    how do i remove the cover which covers the cord assy on the bottom? cord needs to be rewound.
    ..................................message ends.....................................................
    Problem Solver:
  • 17 Answers
If it's the one in the picture then pop off the light cover by gently pushing in and prying on both sides . Remove the bulb by pushing and twisting , OK?, now see the 2 screws? take them out. now flip over the powerhead and gently pry at both sides toward the rear wheels.
Ta Daa!
Posted on Oct 02, 2008
  • 701 Answers
The belt you need can be found here:
Posted on Oct 25, 2009
My husband accidentally dislodged the belt on my kenmore canister vac. how can we disassemble the head to put the belt back on?
There should be 4-5 screws on the bottom of the brush assembly, remove them and you will see the brush and belt, remove each end of the brush assembly they should lift up and out of the housing,and either replace or reailine the belt on the motor side of the housing.
Aug 25, 2014 | Kenmore Progressive Canister Vac Cleaner...
Need to replace powerhead belt in sears canister vac - cannot get head apart - plz advise
If you press on either side of the raised top light cover it will come off. Then you will be able to see the light bulb and two screw heads. Remove the two screws and the top cover of the power brush will lift off and you will be able to access the belt. You can find this belt you need here:
Sears Powermate Canister Belts
Nov 15, 2009 | Vacuums
What belt do i need for a kenmore canister vac 116023513304
I'm not familiar with the model number that you posted. But if the picture you posted is the model you have then this is the belt you need
Oct 15, 2009 | Kenmore 22812 Bagged Canister Vacuum
Replace belt on cartpet attachment (kenmore)
on the newer models remove 2 screws on the bottom of the powerhead,also you need to pry the cover of in the back and sides.
they slip over a little ledge and hook to hold in place
Feb 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Powerhead does not work and the light doesn't work. Canister does work
Some of these has a reset button to push on the powerhead. Check the plug at the end of the hose handle, is it pushed in, if you push on it and it goes further in, then the tube in the handle will have to be replaced, the holding tab broke off of the tube. Pull the wand off and look at the prongs to see if they are burnt. it they are, then that power cord will have to replace as well as the want.
Jan 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
476 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
