Question about Acer Aspire 5500 5570-2609 Laptop
Acer 5570 after trying to download a microsoft sp1 update for vista windows, the download stopped and I cannot reboot my laptop. The information reads: Windows failed to load because a critical system driver is missing or corrupt. File: windowssystem32driversintelide.sys Status: 0xc000000f. All options in the "windows error recovery" section failed.
  • Anonymous Mar 21, 2014
    windows fails to load
    Novelist:
  • 169 Answers
Several things you can try...first, if System Restore is enabled (not recommended because viruses love to eat and grow in there), boot into Safe Mode (F8 at startup). If you can get into safe mode, go to Start, Programs, Accessories, System Tools, System Restore ...the SP update automatically creates a restore point before it begins (about the only thing that Microsoft actually got right!), and you should be able to select that restore point and go back to before you ran the update.
If that does not work, or you cannot get into safe mode, then you will need to run a Windows repair using your original Windows CD or factory recovery disc(s). Make sure to run a "repair", not a "clean install", else you will lose all your data. (if you don't care about saving data, I recommend a clean install).
If the repair doesn't work, your only real choice is to do a clean install, following the steps just above. However, you will lose all your documents, so if they are important to you, take your computer to a PC service tech or facility and have them backup your files first. It'll cost you, but probably not that much. I normally charge my clients $60/hr to backup their data, and usually it only takes about 30 minutes for 1-5GB of data.
After that (or without that), run the Windows "clean" install and you're back in business!
Hope this helps - remember to rate :)
Scott
Posted on Oct 02, 2008
Sound is not comming when i change window XP from window vista
Your PC requires a more recent soundcard device driver that is compatible with Windows Vista.
You can download the required driver here-
http://support.acer-euro.com/drivers/desktop/aspire_t180.html#driver
Please be aware that there is a different driver for Microsoft vista sp1 and above as opposed to Microsoft Vista. SP means service Pack which is a combination of updates supplied by Microsoft to make your operating system more reliable, secure etc.
If you do not know whether you have SP 1 installed, click on the start menu, right click on the computer and click on properties. Your Windows operating system is now described in the top of the window. It will say something like Microsoft Vista or Microsoft Vista SP1.
//javaftper
Aug 02, 2010 | Acer Aspire™ T180 PC Desktop
Hard drive will not completely finish installing Vista Sp1.
Try booting in Safe Mode (press F8 during startup). Once in safe mode, see if you can see the update in the Add/Remove programs from the Control Panel. Make sure the select the "View updates" checkbox.
If it is there, try uninstalling it before you boot in regular mode again.
While in Safe Mode, also disable the automatic Windows update. You can then try to install it manually from the Microsoft site instead.
Microsoft has some more ideas on how to fix SP installation.
Jules
Jul 16, 2009 | Samsung HM060HI Hard Drive
Cannot get out of Configurating updates: stage 3 of 3 screen
This is all I could find:
It's not only Windows Vista Service Pack 1 that isn't ready for general consumer availability. Some of the updates released on February 12, 2008, as a part of the Microsoft monthly patch cycle, have managed to effectively kill Windows Vista. Users are reporting that, following the introduction of the February 12 updates, Vista gets stuck at the finalization of the deployment of the updates displaying the message "Configuring Updates Stage 3 of 3 0% completes" and then entering
an infinite reboot loop. And there is absolutely no way out for the end users, because canceling the configuration process of the updates is a move equivalent to losing access to the operating system entirely. This will even happen in Safe Mode.
Microsoft has yet to officially respond to the issue, or to provide a resolve or at least a workaround. However, it does seem at this point that there is an issue with the deployment of the pre-requisite updates necessary for the smooth installation of Windows Vista SP1. Namely, the problem resides in the Vista installation software. The fact of the matter is that end users will have to first update the Vista installation software and only then deploy the remaining February 12 updates and only at the end Vista SP1 RTM.
If you are stuck watching the "Configuring Updates Stage 3 of 3 0% complete Do not turn off Computer" and in the endless reboot loop, then stop the cycle and boot from the Vista media. You will need to "Repair your computer," so select your Vista installation and restore it to a point before the deployment of the updates. After gaining back access to your operating system, you will have to install the service stack update, namely Update for Windows Vista (KB937287). Deploy this update before any other on your Vista, and only then install the rest. At this point in time, you should experience no more problems.
"Update 937287 is a prerequisite package that contains updates to the Windows Vista installation software. The installation software is the component that handles the installation and the removal of software updates, language packs, optional Windows features, and service packs. Update 937287 is necessary to successfully install and to remove Windows Vista SP1 on all versions of Windows Vista," Microsoft revealed.
Dec 18, 2008 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
After installing vista service pack 1 my dvd rom is gone.
I would try stopping the device and restarting it first.
If that doesn't work, find the latest drivers for it, and have them in a folder you can find easily. In device manager, you can right click, go into properties for the DVD-ROM. Click the update drivers button, and point it to that directory.
If neither of those work ,try completely uninstalling it from device manager, then going through the add new hardware option in control panel.
Dec 03, 2008 | Acer Aspire 5500 5570-2609 Laptop
No Audio Output Device is Installed
I had the same problem. After gemoving the service pkg.1 it works correctly. I couldn't remove the SP1 myself so I brought in to the repairshop (35 euro'). Good luck
Aug 08, 2008 | Acer Aspire 5100 Notebook
Download the latest driver for dvd rom from Acer that will work with Vista SP1. Also try uninstalling the device in device manager and restart your computer. Vista may find "new hardware" and install the driver from its driver pack in SP1.
Jul 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5630
Seems like your VISTA upgrade didn't sucessfully upgrade itself from XP to VISTA. Seems like M$ update program detects your OS as XP and tries to install the SP3 for XP. VISTA only has SP1 released. Its currently stuck in a loop that it doesn't know what to do. Restart your laptop into safe mode by pressing F8 before the VISTA loading page comes up and go to Safe mode and backup your data and use the ACER RESTORE CD OR ACER RESTORE METHOD to help you reload your system back to factory defaults then upgrade back to vista without install any updates or connecting it to the internet.
This is my best solution to get you out of this weird and unusual situation.
Jun 30, 2008 | Acer Ferrari 4000 Notebook
Vista service pack!!! i have seen that finally the sp1 pack is out but why cant i get it on my update service??? is it because my laptop is not compatible? and if this is so how can i make it?
I wondered the same until I had loaded all available updates, including optional ones (but I don't know if that last was necessary). Then "voila" SP1 was shown as an available update! You can manually download the SP1 from the update site, but this is a 400+ Mb download. Give it a try. Download and install all available updates (this may take several inspections and installs [each probably requiring a reboot in between] so persevere). Don't think that because you have installed all the (visually) available updates that you have in fact installed ALL the updates, some require a previous update be installed before the next update is identified. This is probably what happens with SP1. Good luck
Apr 07, 2008 | Microsoft Windows Vista Ultimate Edition
Acer Aspire 5500 5570-2609 Laptop Logo
286 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
