Question about Hotpoint WD62 Front Load Washer / Dryer
Drum wont turn
The drum wont turn. The water will fill and empty but the drum doesn't turn for washing or drying. Can you advise me please.
S
  • 139 Answers
Yeh you carbon brushes on the motor need replacing..
easy to do yourself. i have a post or there is a post on this site.
All you do is remove the top lid by unding the three screws at the back and pulling it back.
You will c the motor atached to the top of the drum. Now myself personally have a set of 90degree bent nose pliers specially for this job i dont know abbout you. You will c two white looking plugs inserted at the back end of the motor remove these and replace.
Howver on some models diffrent motors are used where you undue the carbons with a screw drive and replace.
Good luck Washdoctor..
Please rate me. the solution is adead cert. new brushes cost around £5 to £10 pounds
Posted on Oct 02, 2008
Hotpoint WMF760 fills but won't wash
http://www.how-to-repair.com/help/faqs/hotpoint-wml540-washing-machine-that-wont-start/
Aug 30, 2016 | Hotpoint Washing Machines
Finding water in the washer after it sits idle for a few hours. Wife tells me that she completes a wash cycle as normal, moves the clothes to the dry emptying the washer. Then later in the day she returns...
yes its a leaky solenoid water inlet valve,shut off each water fill valve after using the machine and check the drum later to see if its still empty,then do the other4 valve and when you find water then thats the leaky valve,don't try to clean it,just replace the entire valve
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Drum wont spin
Check brushes in motor, replace if worn
Oct 01, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Drum wont turn
check for worn carbon brushs in the motor.good luck!
Dec 01, 2007 | Hotpoint First Edition WMA20 Front Load...
Water in drum
It sounds like you have a faulty fill valve that is leaking by. The valve has an electric solenoid but also has a small diaphragm that needs to seat properly to keep the water supply from coming in. If the diaphragm is not seating correctly for whatever reason, water pressure alone can keep water filling into the wash tub. Even the smallest amount, over time can cause problems. One way to test the theory is to shut off the water supply before you go to bed. If the tub is still empty in the morning, more than likely you have a bad fill valve. Let me know if this helps.
Jul 09, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Hotpoint WD62 Front Load Washer / Dryer Logo
95 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
