Question about U-Line 75WC Wine Cooler
Unit not working
My uline is two years old and all of a sudden stopped cooling. I made sure the outlet was working .
  • 958 Answers
Could be a thermostat problem, check the thermostat for continuity. it should have, if not, then replace the thermostat.
tnx 4 using fixya,
drcool
Posted on Oct 01, 2008
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
U-line bar refrig/icemaker
The fact that the compressor is two years old does not mean it cannot break down again, give more details on the problem to troubleshoot further
May 27, 2008 | U-Line Refrigerator Ice Maker
My ice maker gets cold but will not make ice
I assume you have a good water supply ti the unit.
An internal switch of thermostat may have failed inside the ice maker head unit.
A good repair shop should be able to fix it.
If the unit is several years old it may be best to replace the icemaker.
Make sure they are factory authorised to fix uline products.
Jan 16, 2010 | U-Line Icemaker
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
Uline 2075WCS not cooling
Hi!! I'm a uline authorize servicer and yes the repair man is right. you have a leak in the evaporator..remember make sure to call uline ans see if you have warranty on your seal system of the wine cooler..good luck..
Jan 03, 2009 | U-Line 15WC Wine Cooler
My ULine icemaker just started triping the GFCI plug.
Ground fault should not be used when you have a compressor plugged to it. The start amps can trip a ground fault. You can try to plug the unit on a regular outlet and if it doesnt trip the breaker then unit should be good. You can try to replace the ground fault if you need it (but make sure you have a higher amperage on the new one.)
Dec 23, 2008 | U-Line Icemaker
Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
U-Line 75WC Wine Cooler Logo
582 people viewed this question
Top U-Line Furniture Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Sal DeAngelo
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
