it can be the problem of the fan rpm meter or it can be the problem of the fan being away from the processor, if the fan isn't close enough to touch the processor then the motherboard will read it as not turning
Was this helpful?
Yes
No
Solution #3
posted on May 30, 2006
Bouncy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Maybe the RPM sensor (built into the fan) is not working. Try replacing with the correct fan - three wire - red - white - black. Otherwise it's likely a problem with the motherboard's RPM sensor. Shouldn't be a problem unless the fan fails... Then your C
Was this helpful?
Yes
No
Solution #4
Reynolds - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
most likely a 3 or more wire fan or someone has the wrong fan in it. try replacing the fan.
Was this helpful?
Yes
No
Solution #5
Janice - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Could be a loose connection. I'd try replugging the fan in first before buying anything.
Was this helpful?
Yes
No
Solution #6
posted on Jun 18, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
plug it the correct spot -- indicated as CPU FAN on the mobo --
heeee heee
Solution #7
posted on Nov 15, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The Tempest uses a 4 wire fan for the CPUs, not sure how happy it is with 3 wire ones. I heard somewhere that the 3 wires just spin at full speed. Sounds like you have other issues though..
my hp pavillion pc will not work....i am able to access the bios but cannot go into safe mode. can...
(More)
my hp pavillion pc will not work....i am able to access the bios but cannot go into safe mode. can you advise
i have hp pavilion 13121n and mechanic has informed us that dp ic needs replacement. we can get from...
(More)
I HAVE HP PAVILION 13121N AND MECHANIC HAS INFORMED US THAT DP IC NEEDS REPLACEMENT. WE CAN GET FROM HP ONLY. PLEASE HELP
