When i crank to start the service engine light will flash and some times the engine will run for three seconds shuts off
D3 items buy diablo 3 gold buy tera gold provide specific options for other game fanatics in swap for "G Credits", r7onmETa or hold out the in-game "free to play" complement titles that spend out "G Credits" in small quantities and greater than extended term. http://www.avreview.co.uk/forum/forummessages/mps/dt/4/UTN/10700/V/6/SP/330641376512556148220
SOURCE: blower for nissan titan
The picture I will try to attach will show you the blower motor housing. The white electrical harness rt hand upper corner is attached to the blower motor resistor. If you have checked the relay and its working ( you can check with a tester) the resistor is probably the problem. It's the most common a/c blower issue I see weekly hope I can send it and hope it helps.
SOURCE: starter
The starter on the 5.6 L engine is located at the top of the transmission bellhousing. You have to remove the upper intake plenum to get to the starter. You can't really see the starter until the plenum is out of the way.
Hope this is helpful!!
Nissan Scope Technician- 10+ years experience in Nissan dealership
SOURCE: 2004 Nissan would not start
Try checking your battery and or starter. If not them you might have another electrical problem.
SOURCE: how to change fuel filter in 2005 nissan titan
From the information I have been reading the fuel filter is located inside the tank and is part of the 100k-150k maintence period.
SOURCE: service engine soon light 04 nissan titan
i had the same problem on my 04 titan and it was the gas cap.. autozone can flash the system and get rid of the check engine light for u. make sure u twist that gas cap till it clicks from now on
