Question about Cameras
My memory card seems to of blocked, what do I do now? The camera is a samsung S1065.
The memory card has a lock on the side (a little switch), which should be in the right position. It works like the protection on a diskette. It probably came in the lock position when you took it out of the camara.
Posted on Jan 29, 2009
I dont have a disk and i want to download photos from my samsung camera model number S1065
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Mar 31, 2011 | Samsung Digimax D53 Digital Camera
I need samsung s1065 usb driver
Go to samsung's website, go to support and downloads, then do a search for the s1065 usb driver.
Nov 09, 2010 | Computers & Internet
I dont know where to put my memory card in my samsung S1065?
Hello
You will be able to get step by step instructions on installing a memory card at the link below.
Click HERE to navigate to page.
Kind regards
Andrea
Aug 14, 2010 | Cameras
My samsung s1065 camera is saying "card locked "i have not put a code or anything in it so i dont know why its locked an i cannot take any photos or anything
Remove the SD memory card from the camera. Look for the lock switch on the memory card and slide it away from the "lock" position. Re-insert the SD card and all should be well.
SD stands for Secure Digital and was one of the first memory cards to have a physical security lock to protect your data.
Oct 05, 2009 | Fuji FinePix A500 Digital Camera
My camera is a samsung s1065 and it will not read my memory card. There is no photos on the camera's memory or the SD card's memory because i uploaded them to my computer using a "all in one" USB stick...
If the images were "copied" the original images will still be on the disc. Try formatting the memory stick and see if this clears up your situation. If not, write back with specifics.
Jul 08, 2009 | Fuji FinePix A500 Digital Camera
Memory card error samsung s1065
when you view pics it is best to download them to a temp file if you don't want them easy to delete. once the cam views them .
Apr 04, 2017 | Cameras
I have a samsung s1065 and I wonder if you could let me know..
One thing to consider when dragging photos to a memory card for viewing on digital camera, is which folder you are putting them in.
On my sony cyber shot, when I hook it up to remove pictures, I open the memory drive in MY COMPUTER, and are faced with two folders.
I ended up having to click into each one to find where the actual photos were, and there were multiple folders within the original folders.
I guess it is just the way the camera organizes the memory card.
Anyway, if your experience is similar to mine, and you haven't already done so, I would click down to the exact same folder in the memory card where you find pictures you take with the camera.
Drag your computer photos there, and see if they appear.
Hope that helps.
Dec 30, 2008 | Samsung Digimax S630 Digital Camera
Memory
I had thesame problem when I bought my s1065, until I opened the battery compartment & found I had no memory card in, I went to Argus & bought one for £19 50p & now I can take as many photos as I like.
Alf.
Dec 20, 2008 | Samsung Digimax S630 Digital Camera
Memory card fault or camera fault?
When the camera writes the image files to the memory card, it also creates index/information files. Without those files the camera will not display the images.
Check the software you used to upload the images with. There's probably a checkbox or option that tells it to delete the images from the card after uploading them.
Nov 29, 2008 | Gateway DC-M40 Digital Camera
Cameras Logo
81 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
