Question about Optoma EP739 Multimedia Projector
Optoma ep739 won't power up
My optoma projector won't power up at all. I plug in the device and it doesn't go on stand by. It remains as if it was completely unplugged. Any ideas on what could have gone wrong?
  • Ahzrei Oct 15, 2008
    I have the same problem with my ep721.
    Please let me know if you find a solution (ahzrei@hotmail.com)
  • rightofu Mar 10, 2009
    mine just died too, only 800 hrs on the bulb. I never touched the lamp door so I have no idea what caused this?
    any Ideas?
The lamp cover has a disconnect that won't allow power while the cover is off. Sometimes the piece of metal gets bent out of place.
Try removing the cover for the lamp, and bending the little piece of metal forward.
It worked for me!!!!
Posted on Nov 27, 2008
This requires almost complete disassembly of the projector.
Somewhat time consuming, but not hard.
If you are unable to fix the switch, take a jumper from a hard drive, "the one used to configure the drive for a master or slave", unplug the unit from its power source and any other cables connected to it. Disassemble the unit until you can remove the power supply and unplug the switch cable from the power supply.
Pull the complete connector housing, "the white plastic piece the cable plugs in to", off of the power supply board. Be careful with the 2 pins inside of the housing when you remove it, make sure you pull it straight away from the board.
Plug the hard drive jumper onto the 2 pins from which you removed the cable and connector housing. Re-assemble the unit and test it.
Works like a champ.
This is also a great opportunity to blow out the unit while you have it open. Be careful to not over spin the fans, it is better to hold the fans so they do not spin while blowing out with canned air. You can also use an air compressor to blow out, but do not use more than 15lbs. of air.
Good luck.
Posted on Oct 16, 2009
Mine did the same thing. It was a bad power supply. The +5vdc was loading down to 4 volts and below, under load. I replaced all the electrolytics for the DC voltages.
Posted on Jul 12, 2010
Can the Optoma EP739 be ceiling mounted and projected upside down? what are the steps to do so? also, what would be the best mount for said projector?
Mine has been in place for about three years. Because the ceiling was open I was able to create a connection for a tripod head on the ceiling and then using a STRONG tripod head and some small bolts (longer than the originals) I mounted an external base and with the tripod head fitting dttached to the projector it just became a matter of running the various connector cables from the sources I use that require projection to my wall.
Dec 02, 2010 | Optoma EP739 Multimedia Projector
4 narrow bright stripes down left side of screen
reset the projector,if it doesnt help,its probly got to do with ur dlp colour wheel.
Jul 03, 2010 | Optoma EP739 Multimedia Projector
We have a optoma ep739 used at our local football club;but whenit gets warm it cuts out until it cools down;isthere any filters that need cleaning
take the lamp out, there is a fan directly looking to the lamp... clean it with a compressor. and after that at the menu of projector there is a place called 'High Altitude'. turn it on. And it'll be fine...
Mar 01, 2010 | Optoma EP739 Multimedia Projector
Optoma ep739 color was going greenish so i replced the bulb and now it seems to be getting no power at all? i tried several outlets and still no power, no flashing light, no led, nothing. Any suggestions?
These units have many safety interlocks. First make sure that all of the doors that you opened are replaced correctly. If not, the interlocks will prevent any power from getting to the unit. Update this with what you find.
Dan
Jan 29, 2009 | Optoma EP739 Multimedia Projector
Optoma EP739
The lamp cover has a disconnect that wont allow the unit to power on while the cover is off.
Try taking the lamp cover off and bending the little piece of metal you find underneith.
It worked for me.
Nov 01, 2008 | Optoma EP739 Multimedia Projector
Projector has no power
close lamp compartement door firmly because door switch can disconnect power from projector if not closed firmly.
Aug 27, 2008 | Optoma EzPro 739 Multimedia Projector
Powers off and lamp never comes on (new lamp tested in other ep739)
The lamp might be burn out or you do ot have the computer in the right plug and the right input slected.
Jul 23, 2008 | Optoma EP739 Multimedia Projector
Optoma EP739 Projector Overheating
Set the projector to "high altitude mode." It will be noisier, but won't overheat. I wonder whether using one of those $10-$20 laptop coolers underneath it might be a quieter solution.
Mar 09, 2008 | Cameras
Optoma EP739 Multimedia Projector Logo
1,318 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
