Carrier (outside) Coleman Evcon (inside) Air Conditioning question
Hey guys,
I have a Coleman 38TKB060 outside unit and an Evcon gas heater/cooler inside unit that I'm having trouble with.
The entire unit went out last night on me as if it's not getting power. I tested the power supply to my inside unit in my attic and I'm getting 120 volts to it. I followed the power supply down and I know it also goes to the 24v transformer. But, I couldn't test the power coming out of that transformer. I did test where the 24v line runs from the attic unit to my thermostat on the wall and where the 24v line runs to my outside unit and neither is getting 24 volts.
There are only 2 items power travels through on this path. The 24v transformer and another large "box" (for a lack of a better word) that controls the fan and sends the 24v power to the thermostat and to my outside unit.
Does that sound like a blown transformer? Can that happen?
If that's the problem can I do it myself? And if so, how do I know which one to buy?
Thanks for your help.
  • DanielV Oct 02, 2008
    Hey Dr. Cool,
    I tested my transformer and I wasn't getting anything out of it. I replaced it myself ($9.75 part) and saw life again. I'm now back in business.
    Repair man would've charged me 100+ I'm sure. Just needed to test the input/output of it and have a little patience reading a wiring diagram.
    Thanks again,
    Daniel
  • 958 Answers
Transformer has just 4 leads. 2 for primary which is your 110 volts and 2 for secondary which is supposed to be 24 volts ac. if you splice the two secondary wires coming out of your transformer, you should be able to get a 24 v ac there.
the box that you are referring to could be a fire controller that in case of fire, it would shut off the fan and the compressor outside.
tnx 4 using fixya,
drcool
Posted on Oct 01, 2008
  • francis rivero Oct 02, 2008
    your very much welcome daniel.
    glad to be of assistance to you.
    tnx 4 using fixya,
    drcool
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
I have a coleman evcon gas furnace in a 95 trailer the draft fan stays on until you tap on furnace
Most Coleman units in a trailer dont have a draft fan. Are you talking about the fan that blows air through the floor registers? If yes, then you will probably need a new fan/limit control. If you do have a draft motor, you would probably need a new circuit board or draft fan relay.
Jan 02, 2010 | Coleman Propane Forced Air Heater...
Dripping water from pan or coils
If the a-coil is on the suction side of the blower, the drain line needs to be trapped. take enough hose to make a circle below the drain fitting and then into the drain. The blower causes a suction up the drain line if it is not trapped and will not let the water go out the hose.
Aug 03, 2009 | Coleman Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Coleman evcon furnace
is the air filter clean afc could be dirty
Dec 22, 2008 | Coleman Propane Forced Air Heater...
Rollout Limit Switch Keeps Tripping
have someone check the gas presure most likely too high no more than 11
Dec 14, 2008 | Coleman Propane Forced Air Heater...
Coleman Evcon..... Inducer Adjustment
Just wanted to make sure you knew this model is on a recall list:
http://www.dgatprogram.com/
Dec 10, 2008 | Coleman Propane Forced Air Heater...
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
288 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
