Question about Samsung SCX 4200 All-In-One Laser Printer
Xerox PE120 Just purchased a xerox PE120 and it continues to show open heat error and doesn't work
  • thogan Oct 23, 2008
    Open heat error, wont' print
  • bogrady Dec 19, 2008
    I just had the same problem a short time ago. Help! It won't work, it just has "open heat problem" in the message box.
  • 34 Answers
Your pb around fuser zone
Posted on Sep 16, 2009
Need drivers for Windows 7 for my xerox workcentre pe120i
A Windows 7 driver is not available, but you may find that the Vista driver works OK. You can get it here:
http://www.support.xerox.com/support/workcentre-pe120-pe120i/downloads/enus.html?operatingSystem=winvista&fileLanguage=en
Feb 15, 2011 | Xerox WorkCenter PE120i All-In-One Laser...
Open Heat error on my xerox workcentre PE120 which I think I need to buy a fuse can you help
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 01, 2010 | Xerox WorkCentre PE120 All-In-One Laser...
Will not print shows open heat error cycle power on the xerox phaser 3300 mfp
First try turning the machine off and back on. If they error continues you most likely need to replace the fuser (part number 126N00265 for 110V U.S. or 126N00266 for the 220V U.K. version). ItemInc.com has these in stock and ships same day. Just open the rear door and unscrew the 4 screws using a phillips screw driver to remove it. Here is a video that shows you how. Hope this helps, and thanks for using FixYa!
Jul 07, 2010 | Office Equipment & Supplies
Open heat xerox PE120
You have a bad fuser assembly. It will need to be replaced.
Dec 22, 2009 | Office Equipment & Supplies
Open heat error
if you meant to write over heat error, it should go away after the fuser cools down. if it continues to happen, the fuser unit will need to be repaired or replaced
Nov 02, 2009 | Xerox CopyCentre C20 Black and White...
Diaplay shows open heat error after one print.
The fuser is overheating. Probably now has blown the overheat thermostat. You have to replace the fuser to get rid of it. Not real hard to do.
Mar 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox PE120 i dirty platen glass
there are only little plastic lock only, try with technician.
Feb 26, 2009 | Xerox PE120i Laser Printer
Error code PCL6 incomplete session by time out
That is normally caused by firmware corruption. You can go to Xerox.com, click on support and drivers, then in the search box enter pe120, then go to drivers and downloads and download the newest machine firmware . There are directions on how to install the firmware , make sure you follow them step by step. It's pretty easy and should resolve your problem.
Feb 12, 2009 | Xerox WorkCentre PE120 All-In-One Laser...
Workcentre pe 120i memory full
in spec. say's so:
your workcentre Pe120 have only 32 Mb memory.
fax function is equipped with a 4 Mb standard memory.
In spec. shows a 4mb memory is just enough for 320 pages of fax!!!
i think your problem is given from the 32 mb of memory of workcentre pe120, not from fax memory, because the faxes received or delayed is compressed with a very strong altgorithm, and these files is very small.
http://www.office.xerox.com/multifunction-printer/multifunction-under-30ppm/workcentre-pe120-pe120i/spec-enus.html#Memory
a link bellow ; i think is useful:
http://www.xeroxdirect.com/direct/public/products/accessorizer/dsp_accessory.cfm
for a 32 MB memory module (product code is: 097n01434)
Sep 23, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Driver for mac OS for Dell 1600n
If you install the Xerox1600n it should work for you. That is what we had to do.
Feb 24, 2008 | Dell 1600n All-In-One Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
132 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
