Cant get external harddrive uploaded to my laptop
    Sergeant:
  • 268 Answers
If it is a new external hard drive you may need to partition it first....
  1. Click "Start"
  2. Click "Control Panel"
  3. Double Click "Administrative Tools"
  4. Double Click "Computer Managment"
  5. Expand the section that says "Storage"
  6. Click "Disk Managment"
  7. Here you will see all the drives on your computer. You should notice a black bar that says "Unallocated Space"
  8. Right click on that , and hit "New Partition"
  9. Go through the wizard (at one point it will ask what type of drive, make it a "Primary Partition"
When you are done with the wizard you should be able to see the drive!
If you try this and have any issue's , leave a comment here and I will be more then glad to further assist you.
Posted on Oct 01, 2008
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
My acer chromebook AC710 SCREEN IS CRAZY CANT SEE ANYTHING BUT COLORS AN LINES WHAT TO DO?
The reason your monitor is in screensaver mode, (Read your other problem too), is there is no video signal coming to it.
No Signal
This is because the Netbook isn't sending one.
It isn't sending one because apparently you have graphics problems. Problems with graphics hardware.
So no, there is no Sync, or settings to change on the monitor.
(It is Not a video/graphics card. Your laptop uses Integrated Graphics. Intel HD 3000 Graphics )
However the point is moot now. Netbook is being sent in.
Point now is getting the info off the Harddrive, before some geek looses it.
(I'm a computer geek too, so that was no slam)
Remove the Harddrive. Then install it in an external enclosure.
You've seen an external enclosure, if you have seen an external harddrive.
You can buy just that 'outside case', too.
The external enclosure has a USB cable going to it.
The USB cable goes inside the enclosure, and connects to a small circuit board, with an interface on it.
The harddrive plugs into the interface.
The external enclosure comes apart VERY easily. Manufacturers make it easy to open the external enclosure, and install the Harddrive.
Usually a 2 piece case. One screw to open. Remove cover, plug Harddrive in, replace cover.
Plug USB cable into a USB port, on a working computer.
This is one example that will work with your Harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
[Harddrives are measured across their width.
A laptop harddrive is 2.5 inches across in Width. 2-1/2 inches.
A desktop harddrive is 3.5 inches across in Width.
Three technology styles of Harddrive, are presently being used;
1) IDE (PATA),
http://en.wikipedia.org/wiki/Parallel_ATA
2) SATA,
http://en.wikipedia.org/wiki/Serial_ATA
These two types of Harddrives use mechanical parts. For example a Spindle, Spindle Motor, and Platters,
http://computer.howstuffworks.com/hard-disk.htm
3) SSD,
http://en.wikipedia.org/wiki/SSD
No mechanical parts. Just electronic components. (Solid State)
Your laptop uses a 2.5 SATA harddrive ]
Going on..................
I haven't had any direct dealings with this laptop. Or the Aspire V5-171 version.
I see no Service Manual listed.
Searching the internet for Harddrive replacement info though, I ran into that there is a large panel on the Bottom of the Netbook; which has a single Philips head screw in the middle.
Remove the screw, remove the large panel.
This is supposed to be in the User's Guide, but cannot seem to download it right now to see.
It will be in replace the Memory. Ram Memory.
The Harddrive should sit in a compartment area all it's own.
The Harddrive itself will be in a sheet metal Caddy. Harddrive Caddy.
Remove a screw, or screws; to remove Harddrive, and Harddrive Caddy.
Once screw/s are removed, L@@K at the Harddrive.
There should be a piece of 'silk strap', to pull on.
Keeping Harddrive flat, and down in Netbook, pull on the strap; and pull the Harddrive across towards the OUTSIDE of the Netbook.
You are unplugging it.
You DO NOT want to lift straight up on the strap, as you will bend contact pins.
Once the Harddrive is slid over, then lift at an angle; and remove.
Lift up on the Back of the Harddrive.
This is the opposite side of the one that plugs in.
Open the external enclosure case, slide the harddrive in; then close the external enclosure case. (Referring to Tigerdirect example. Other external enclosures will be different)
Plug the USB cable into any working computer's open USB port.
Look in My Computer/Computer. (WinXP/WinVista - Win 7)
The external harddrive will be shown.
DOUBLE-click on the drive letter it is next to.
Have problems with that post back in a Comment.
Your Netbook, is supposed to be just an ACER Aspire V5-171 series of Notebook PC; with a Chrome logo on it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 05, 2013 | Acer Computers & Internet
Hi Andrea I have just connected a hard drive to my Laptop and it isn't recogized.. can you help. I'm running on Windows XP Thanks Ian
Not Andrea, just wanted to offer;
1) Installed a new larger Harddrive for the laptop?
There is a special procedure for this. Depends on what laptop we're discussing here.
A new harddrive will have no operating system on it. BIOS needs to recognize the harddrive.
{When you press the Power On button of your laptop, the first chipset to receive power is the BIOS chipset. BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on, and hands the laptop over to the Operating System. WinXP is one example of an O/S }
Some laptops have a procedure where basic info is stored until the new harddrive is installed. Then the basic info is transferred to the new harddrive.
In any case I suggest going into the BIOS Setup, and on the main page see if the Harddrive is recognized.
It will be listed.
If it isn't listed you have to manually set the harddrive's parameters. (Type them in)
The Cylinders, Heads, and Sectors.
When BIOS recognizes the harddrive, then you can install Windows XP off of the Restoration Disk, (Repair. Also know as Non-Destructive Installation), or a fresh, new genuine copy.
2) If this is a reference to an external harddrive, there may be an electronic problem with the unit.
The main problem that happens with an external harddrive, is the small circuit board inside goes bad.
This small circuit board is an Interface Board.
It connects to the Harddrive inside the case of the external harddrive, and allows a USB cable to be used.
If this is found to be the problem simply remove the harddrive inside, and install it into an economical external enclosure.
Awaiting further information so I know what we are dealing with.
A) Is this a reference to a new harddrive being installed into the laptop?
If so, laptop manufacturer name, and Model Number.
(Bottom of laptop in a white Service Tag, or sticker)
B) Is this a reference to an extermal harddrive?
Manufacturer name, and Model Number
Regards,
joecoolvette
Oct 25, 2011 | Computers & Internet
WD 500G HDD suddenly un-readable; changed name to local disk, says I need to format in order to use it. I have tons of important stuff on there.
Could you confirm if the problem with the drive not being recognized is a problem with the USB cable? I have a 250GB passport and it worked fine with my XP. Once I decided to reformat it to NTFS and tried to do so by plugging into my new windows7 laptop the problems started.
Aug 21, 2011 | Western Digital My Passport Essential...
My lacie drive fell off desktop and is not recognized as readable by my Mac. What chance do I have of recovering the data?
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive.
The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure.
(Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem?
No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive.
However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into.
It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board.
Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside.
The room used is a Clean Room.
A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed.
Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room.
They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
http://www.youtube.com/watch?v=gpY8c7lT_7k&feature=related
http://www.youtube.com/watch?v=ax390l2A-AY
Observe the other videos also.
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure,
(The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
SATA 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4421576&CatId=2780
Regards,
joecoolvette
Jul 02, 2011 | LaCie Hard Disk design by Neil Poulton...
Can not get computer to recognize hard drive any more?
You could try using another USB port on your computer. Perhaps that USB port you have the IOmega external harddrive plugged into is bad.
More than likely not, though.
The problem is usually inside the IOmega's case. (External enclosure)
Inside that IOmega external harddrive's case is a regular harddrive as used in a desktop, or laptop computer.
To explain;
Harddrives are physically rated in width, as well as type, and size.
A laptop harddrive is 2.5 inches across in width. (2 and a half inches)
A desktop harddrive is 3.5 inches.
The larger desktop harddrives are usually used in external harddrives that are 500GB, and larger.
(Not always the case when it comes to the 500GB size)
Harddrives have two technologies, or types.
IDE (PATA) or SATA.
You didn't state the Model Number so I can't even hazard a guess at this point.
The harddrive inside the case plugs into an Interface.
The Interface may be separate, and connected via a cable to a small circuit board, or the Interface may be soldered directly to the small circuit board.
It is this Interface, and circuit board which go bad.
The solution is to remove the harddrive inside, purchase an inexpensive external enclosure, and install the harddrive into it.
The external enclosure has a USB cable just like the IOmega external harddrive did.
As stated the harddrive inside is just a normal harddrive. Made by a harddrive manufacturer.
Could be a Western Digital, or Seagate, or Hitachi, or Maxtor, or Fujitsu, or IBM, just to name a few.
(Seagate bought out Maxtor)
On the harddrive will be a decal with it's specifications.
You will also be able to physically measure the width.
This external hookup will support harddrives that are 2.5, or 3.5 inches in width, (And 5.25), plus will support both IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220658&CatId=3770
This external enclosure is for a desktop sized harddrive, 3.5 inches, and will support either IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951866&CatId=2780
This external enclosure example is for laptop sized harddrives, 2.5 inches, and will support either IDE, (PATA), or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Just one example of how to disassemble an IOmega Select Portable harddrive,
http://www.youtube.com/watch?v=NvUvz5Qb4vw
Other styles are listed in the Suggestions column down on the right.
Not a good source for information on disassembling an IOmega external harddrive, but there is very little info available.
(It isn't that tough for any external harddrive enclosure. The screws are usually hidden under labels, and the case pops apart in two halves. Just a little different design here, and there)
Regards,
joecoolvette
Jun 14, 2011 | Iomega Computers & Internet
I need a new internal power supply for my 2tb external its an Iomega prestige. I just want the part number for it so i can order a new one.
There is no internal power supply. The unit gets it's power from the computer. A USB port has 5 Volts DC.
Inside that external enclosure of the IOmega external harddrive is just an ordinary harddrive as used in a desktop computer. A SATA harddrive.
The harddrive plugs into a small circuit board with an interface on it, or there are cables, (wires), which come from the circuit board, and plug into the back of the harddrive.
It is this small circuit board that is usually the problem.
The solution to this problem is to simply just buy an economical external enclosure, and install the harddrive out of the IOmega into it.
Just one example from a quick search for an economical SATA 3.5 external enclosure,
(Note*
A laptop harddrive is 2.5 inches across in width. 2 and 1/2 inches.
A desktop harddrive is 3.5),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Have additional questions or need clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Iomega 2TB Prestige External Hard Drive
1TB WD essentials external harddrive timing out.
Well, never mind then. A simple usb port swap did the trick. Always something simple...
Sep 04, 2009 | Computers & Internet
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Dell 5100 laptop
if you can hear the one beep sound when booting that means your laptop's system is in good condition. try putting it in the external monitor if still you cant see anything both in external and the LCD just install the old keyboard and press the Fn then external monitor... hope this helps...
Jan 20, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
David Payne
David Payne
