Question about Refrigerators
Whirlpool GD5SHAXLQ02 ice maker quit working
Stoped making ice.
Sensor light was not working.
Unpluged AC power for 15 seconds.
Sensor light begins working normaly.
No ice.
What should I check next?
I'm a electronics tech and not afraid to get into it.
Thanks
    Problem Solver:
  • 10 Answers
The the rubber fill spout was frozen with ice. Also the reservoir that acts as a funnel for the fill spout was frozen with ice. Cleared the ice and all works fine!
Posted on Oct 03, 2008
I have a Whirlpool Model GD5YHA. The icemaker is not making ice. The red light is blinking.
Your have not given the full model #. Anyway most likely you have the Ice Maker Optical Level Sensor.
Just red light blinking does not mean faulty here. There is a Optical Sensor check sheet. You have to follow those instructions.
Google "Whirlpool Ice Maker Optical Sensor check sheet". You will get the instruction sheet and/or youtube videos on the subject.
Not making Ice means either the ice maker is faulty or Optical sensor faulty or water valve cannot feed water due to malfunction or line frozen. Also freezer should be below - 12C to ice maker sensor to work.
Oct 25, 2017 | Whirlpool Refrigerators
Power surge caused appliance to go out. refrigerator ice maker now not making ice. has water on but no ice help
Reset the ice maker:
Locate the switch next to the water filter status light.
Press the light switch five times in 10 seconds or less.
Wait for the status light to change from red to green.
Mar 02, 2015 | Whirlpool Refrigerators
Ice maker stoped,is there a reset button ? Filter has been replaced.Have tried the hair dryer .
Let's begin by filling your ice maker with tapo water if now small cubews are in tray. If after the water freezes and the ice drops into the ice bin and does not refill itself with water this will point to the=> 67006322 Dual Water Control Valve Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
Jun 02, 2012 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker stoped working
Jun 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker doesn't work!
Could be the sensor for the ice maker to fill up....we have a wire bar that flips up when full so it shuts off ....also a piece of ice gets stuck in the plastic fingers somtimes but since you defrosted it that shouldn't be the problem....not sure if you can take the ice maker out yourself ...better call the repair man ...
Jan 12, 2009 | Whirlpool Refrigerators
Ice maker stopped working
maybe the valve letting the water in to the ice making part has failed
or a thermostat issue
Apr 29, 2017 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool ice maker stoped working
1. sometimes the water filter
2. the motor to pump the water to the ice maker
3.the ice maker out of order
Jun 18, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Ice maker is not working but water dispenser is.
Try the following check:
First make sure that the temperature in the freezer is 5 degrees or below.
Self-Diagnostics
Unplug the fridge and then plug it back in.
If the compressor is running when you unplug it make sure that you wait 15 minutes before you plug it back in.
You will then have 60 second to open the freezer door and 2 second to view the LED output code.
Ice maker check 3 pulses pause 3 pulses
Optics receiver 4 pulses pause 4 pulses.
Optics emitter and receiver 2 pulses pause 2 pulses.
All good 5 seconds on
Dec 28, 2007 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
595 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
