Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
Secure internet connection
My internet connection states it is not secure. I have a linksys router with a HP notebook
  • mj49938 Oct 01, 2008
    the solution you gave me worked. The problem has been solved. Thanx ever so much for your quick response and help.
    Brigadier General:
  • 6,966 Answers
To secure a wireless network connection, either WEP or PSK has to be enable in the LinkSys router and a passkey designated/chose. This passkey must then be likewise encoded into your HP notebook wireless networking.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 01, 2008
Can't get my friends motorola photon to connect wirelessly with my linksys WRT160N
Please see if you have a secured wireless network.
Go to 192.168.1.1 from Internet explorer.
User id =blank
Password =ADMIN
Go to wireless security tab and get the security key from there
try this while connecting to the network.
Dec 29, 2012 | Linksys WRT160N Wireless Router
I have a wireless network connectionto my linksys router on my hp notebook but can't access the internet.
check the internet settings in internet explorer and check that there are no proxies set, also use another computer to check that there is an internet connection
Sep 19, 2009 | HP Pavilion Ze4805us Notebook
I have hooked it up as the instructions state but it will not find the internet, I am useing a hp laptop and am trying to go wireless, it is the vista system
No its not your windows system, try to check again your wireless router if the software firmware are installed properly in your PC. Also to configure it and connect your internet provider to the Router, which is automatically create its own Protocol Address or Obtain Address, even on Wireless connection. This is basic on Wireless Router to connect on the internet. Good luck!
Aug 04, 2009 | Linksys Wireless-N WRT150N Router
HP laptop not recognizing Linksys Wireless B Security Key..
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Mar 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Adapter/router connected. Still unable to access internet
linksys has an excellent website setup utility.
go to www.linksys.com and click on support.... select the appropriate choice and it will walk you thru it setting up your devices automatically
Robert
Jan 03, 2009 | HP Pavilion N5415 Notebook
Lg r 405 will not recognize wireless signal from lynksys wrt350n
hi i would suggest to access your routers setuppage and set the channel to channel 11.
make sure also if your wireless network is secured, type the correct key those things are case sensitive.
to access the routers setuppage go to a computers that is connected to your linksys router (wired) then launch IE on the address bar type 192.168.1.1(this is the routers ip) then it will ask you for username and password for the username dont type any thing for the password type admin.
when your on the setuppage click on wireless tab. while on the wireless page set the channel to 11.
after that click apply or save settings on the page.
then after that try to connect to your wireless network on your laptop.
for further help you can call linksys hot line 1800-3267114
they will surely help you with this.
hope this helps.
Oct 19, 2008 | LG X-Note LM50 Notebook
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Wireless connection failed?
FIRST, LET ME ASK IS THE DESKTOP WIRED---MODEM-ROUTER-COMPUTER
LET ME KNOW AND THEN I CAN HELP YOU. WE CAN DO A STEP BY STEP. I HAVE THE SAME ROUTER.
GET BACK TO ME
Mar 28, 2008 | Linksys Wireless-G WRT54GS Router...
Connecting to internect
Hi Linda........
1. You can disconnect the Rj45 cable from the PC & connect
it directly to your notebook's Rj45 port. You should have access to the internet if a minute or two.
2. if you want access to both, Pc & notebook you'll need a wireless router. Like the link below. Click it.
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01
You can find these types of wireless routers at places like Wallmart & Best Buy. They come in even smaller packages.
With the software that is included you'll be connected to the internet in no time. Linksys also provides security so someone near to your home can not tap your internet service & get a free ride. Linksys provides setup assistance from day one.
Hope this helps you Linda!
please vote...
Feb 25, 2008 | Dell Latitude C600 Notebook
Computers & Internet Logo
164 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
