Question about Sony LBT-D990 Shelf System
Sony compact disc receiver LBT-D990
The laser lens is not reading, I change it allready but still has the same troubles. It uses the KSS-213D. I bought it from Sony.
  • villacom Oct 02, 2008
    Thank welcomejee for answer me but when I install it I unsold laser diode protection allready and still has the troubles( the laser lens is not reading)
  • 10,594 Answers
KSS-213D lens has soldered joint to protect laser diode from static voltages damage when it shipped. You need to unsold laser diode protection joint and then try.
Posted on Oct 01, 2008
  • Shahid Electronics
    Shahid Electronics Oct 02, 2008
    Here electronic technical work starts.
    Please confirm S Curve as per below level.
    Please check RF level as per below mention picture at RF Test Point on RF Board.
    Above said wave form can be seen by using Oscilloscope.
Sony 5 disc player CDP-CE335 ?
you can still get the lasers for these. If that is what it needs. read the kss # on the side of the laser . Might say something like kss210 or kss213. Andrews electronics has these cheap. Larry
Aug 18, 2015 | Sony Audio Players & Recorders
Lbt-117 compact hi fi system
Could be simply a dusty laser lens. Try a cleaning CD first.
After that, it could be that the laser assembly has low power output. Some decks have the range to increase the laser power, but it's only a temporary fix. The emissions are dying so the laser assembly will need to be replaced sooner of later..
Sep 06, 2014 | Audio Players & Recorders
Sony lbt-d117cd shows no disc playing
After that, it could be that the laser assembly has low power output. Some decks have the range to increase the laser power, but it's only a temporary fix. The emissions are dying so the laser assembly will need to be replaced sooner of later...
Sep 04, 2014 | Audio Players & Recorders
With my sony LBT-ZX66i shelf system when i insert a disc, it starts reading and then says NO DISC.
Sounds like the optical pickup (laser) has gone bad and needs to be replaced.
Mar 19, 2013 | Sony LBT-ZX66i Shelf System
The sony lbt-xb20 is not a console, its a compact hifi stereo system ive cleaned the laser but still comes up no disc its a 5 cd changer
You should examine the carriage that mounts the laser/lens, make certain it can move. You should also try cleaning it with Servisol video 40 or lens cleaning fluid if you have not done this allready. Looking a the lens with a magnifying glass might reveal damage to it.
The model number of the lens unit should be on it. It might start with the letters KSS.
If you don need a new one then I have to tell you it won't be cheap.
Jan 28, 2013 | Audio Players & Recorders
Try to play a disk and an error oo4 comes up
The player doesn't like the brand of CDR your playing. Try using just a CD burner instead of a combo CD/DVD burner. Also use Verbatim Pastel brand, because the player recognizes these discs easier. Also, it wouldn't hurt for you to run a commercial disc laser cleaner through this thing to clean the optical lens. Burn music using Nero software because its easy and the best.
Dec 28, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Sony ps2 read disc error problem
Now this is strange PS2 hangs up..............!!!wHich pS2 u have.........???slim or the old fat one.........???As far as disc read errors are there, u should clean ur lens by using some lens cleaner CD or do it manually[for fat one] urself it not a big deal........becarefull while opening the cover....clean the dust on lens with the tissue or any other light material......the problem can also b with ur disc change that also...........
Sep 17, 2008 | Sony PlayStation 2 (PS2) Console
Sony CFG 656
The laser is eithr dirty or damaged.
Open the lid and look at the laser eye. Take a q-tip and some rubbing alcohol and gently swab the lens, then IMMEDIATLY blow dry with some canned air. If this does not fix it, the laser needs replaced. It is probably a KSS-213 (you can usually peek in the hole that the lens slides along to see), which is widely available on the internet for around $15. Changing it is best left to a service shop.
Aug 04, 2008 | Sony Boom Box With CD Player & Cassette...
Sony LBT-D990 Shelf System Logo
276 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
