Question about Dell Dimension 3000 PC Desktop
Keyboard buttons clicks before typing
When i press a button it makes a click sound before typing. started after my son held down the shift key to long & a window opened.
  • tillie_bryan Oct 01, 2008
    THANK YOU SO MUCH!! It was actualy 'filter keys' but that opened the window, so i could get it turned off. Thank you, (& thanks to this site) for offering your wonderful talent to those of us who are very not good with copmuters.
  • ruthie397 Feb 28, 2009
    I have sticky keys when I type one letter the key stop, then print the next letter what di I need to do. please I canot get the user guide.
    Ruth Chern
  • 5 Answers
If typing the keys make a clicking sound and you can't type the same key twice, you need to turn off filterkeys by press and hold the right shift key for 4 seconds. OR you can go to Control Panel, search for Ease of access. Click on Hear a tone when keys are pressed. Clear the check box Turn on Filter Keys
Posted on Apr 01, 2015
  • 268 Answers
Sounds like he may have turned on the "Sticky Keys", to turn this off , tap the shift key 5 times....should take care of it!
Posted on Oct 01, 2008
  • Chris Callo
    Chris Callo Oct 01, 2008
    Great , I am glad we were able to help you , and thank you for the rating!
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Windows xp keyboard tips
    and also
    Windows system key combinations
    • F1: Help
    • CTRL+ESC: Open Start menu
    • ALT+TAB: Switch between open programs
    • ALT+F4: Quit program
    • SHIFT+DELETE: Delete item permanently
    • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
    Windows program key combinations
    • CTRL+C: Copy
    • CTRL+X: Cut
    • CTRL+V: Paste
    • CTRL+Z: Undo
    • CTRL+B: Bold
    • CTRL+U: Underline
    • CTRL+I: Italic
    Mouse click/keyboard modifier combinations for shell objects
    • SHIFT+right click: Displays a shortcut menu containing alternative commands
    • SHIFT+double click: Runs the alternate default command (the second item on the menu)
    • ALT+double click: Displays properties
    • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
    General keyboard-only commands
    • F1: Starts Windows Help
    • F10: Activates menu bar options
    • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
    • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
    • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
    • CTRL+SHIFT+ESC: Opens Windows Task Manager
    • ALT+DOWN ARROW: Opens a drop-down list box
    • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
    • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
    • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
    • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
    • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
    • ALT+underlined letter in menu: Opens the menu
    • ALT+F4: Closes the current window
    • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
    • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
    Shell objects and general folder/Windows Explorer shortcuts
    For a selected object:
    • F2: Rename object
    • F3: Find all files
    • CTRL+X: Cut
    • CTRL+C: Copy
    • CTRL+V: Paste
    • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
    • ALT+ENTER: Open the properties for the selected object
    To copy a file
    Press and hold down the CTRL key while you drag the file to another folder.
    To create a shortcut
    Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
    General folder/shortcut control
    • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
    • F5: Refreshes the current window.
    • F6: Moves among panes in Windows Explorer
    • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
    • CTRL+Z: Undo the last command
    • CTRL+A: Select all the items in the current window
    • BACKSPACE: Switch to the parent folder
    • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
    Windows Explorer tree control
    • Numeric Keypad *: Expands everything under the current selection
    • Numeric Keypad +: Expands the current selection
    • Numeric Keypad -: Collapses the current selection.
    • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
    • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
    Properties control
    • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
    Accessibility shortcuts
    • Press SHIFT five times: Toggles StickyKeys on and off
    • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
    • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
    • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
    • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
    Microsoft Natural Keyboard keys
    • Windows Logo: Start menu
    • Windows Logo+R: Run dialog box
    • Windows Logo+M: Minimize all
    • SHIFT+Windows Logo+M: Undo minimize all
    • Windows Logo+F1: Help
    • Windows Logo+E: Windows Explorer
    • Windows Logo+F: Find files or folders
    • Windows Logo+D: Minimizes all open windows and displays the desktop
    • CTRL+Windows Logo+F: Find computer
    • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
    • Windows Logo+TAB: Cycle through taskbar buttons
    • Windows Logo+Break: System Properties dialog box
    • Application key: Displays a shortcut menu for the selected item
    Microsoft Natural Keyboard with IntelliType software installed
    • Windows Logo+L: Log off Windows
    • Windows Logo+P: Starts Print Manager
    • Windows Logo+C: Opens Control Panel
    • Windows Logo+V: Starts Clipboard
    • Windows Logo+K: Opens Keyboard Properties dialog box
    • Windows Logo+I: Opens Mouse Properties dialog box
    • Windows Logo+A: Starts Accessibility Options (if installed)
    • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
    • Windows Logo+S: Toggles CAPS LOCK on and off
    Dialog box keyboard commands
    • TAB: Move to the next control in the dialog box
    • SHIFT+TAB: Move to the previous control in the dialog box
    • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
    • ENTER: Equivalent to clicking the selected button (the button with the outline)
    • ESC: Equivalent to clicking the Cancel button
    • ALT+underlined letter in dialog box item: Move to the corresponding item
    on Nov 12, 2014 | Microsoft Windows XP Professional With...
    Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
    You might have "sticky keys" so try this:
    When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
      • Press the "Shift" button five times in a row to turn off sticky keys.
      • Open the "Start" menu and then click "Control Panel."
      • Click "Ease of Access Center" from within the Control Panel window.
      • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
      • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
      • Click "Apply" to save your changes and then click "OK" to close the window.
    Hope this helps. Good Luck!
    Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
    Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
    Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
    b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
    Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
    Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
    Jan 21, 2013 | Acer Computers & Internet
    How do i reset my toshiba satellite L305-S5955 to factory default & erase all data from it?
    Close out any software currently running on your Toshiba Satellite L305 laptop.
    Navigate to the laptop's "Start" menu and choose "Shut Down."
    Hold down the laptop's "0" key and press the power button.
    Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen.
    Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option.
    Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again.
    Wait for the "Press any key" prompt to appear and tap a key to restart the laptop.
    Use the prompts that appear on the screen to choose your region, time zone and keyboard settings.
    Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system.
    hope this helps
    Sep 06, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
    How do i take a screenshot on a lenovo thinkpad r500
    1. Set your computer with the screen you wish to capture.
    2. Click on the "PrtScr" button, usually located on the top right side of the key board.
    3. Click the 'Start' button on the 'Taskbar' and type "Paint" in the search field. Once the Windows find the program, open it, and click on the 'Paste' option on the top left side.
    4. On the keyboard, click "CTRL+S", and save the file on the computer, where it will be able to locate it later.
    5 Send the file as an attachment.
    Aug 01, 2012 | Lenovo ThinkPad R500 2767 PC Notebook
    Caps lock key not working - held down the key for
    Press shift key for at least five times and then release when you hear a peep sound, On the Keyboard tab, uncheck everything and click Ok, if this doesn't solve, then again press five times and uncheck everything and click Ok. I also like to know if you were typing on some program like Ms-Word when the problem occurred. is the caps lock led on? Please let me know so that I can help you better.
    May 06, 2010 | Microsoft Windows XP Home Edition Service...
    When I tpye they stick and wont let me type on
    Ok sounds like you have "Sticky Keys" activated somehow, try this, By pressing the Shift key 5 times, an option windows will appear. To remove the StickyKeys feature, click the Settings button. Then in the resulting accessibility options window, click the Keyboard tab. Uncheck the Use StickyKeys checkbox. Click the StickyKeys Settings button. Uncheck the Use Shortcut checkbox. Click Apply, then click OK twice to exit all open windows.
    Feb 16, 2010 | Toshiba Satellite A100-S8111TD Notebook
    Keyboard Problem
    Holding down the right-side SHIFT key has activated the "Sticky Keys" feature in Windows -- designed for physically-handicapped people who cannot press more than one key at a time.
    Access CONTROL PANEL and disable this "Accessibility Option".
    May 31, 2009 | Logitech Wireless Access Duo Optical...
    Dell Dimension 3000 PC Desktop Logo
    169 people viewed this question
    Alun Cox
