INPUT2: HD15 My computer screen will flash on and off while I'm working on it. After it flashes back on, it will be exactly where I left it, but there will always be a grey little box that says INPUT2: HD15. I have no idea what that function does or means. Is there a way to turn it off or fix it so where my computer doesn't continuously go black in the middle of my work? Also, someone said that I might just have a cord that is loose, but would that cause the INPUT box to flash up everytime it comes back on?
    Genius:
  • 1,124 Answers
Seems to be some problem with your monitor not with your computer. Check monitor settings.
Posted on Oct 01, 2008
My monitor says: "No input
First, are you using the VGA cable (cable with 15-pin on each end), or DVI cable?
It can be that the PC is not sending out the video signals, or loose cable connections, please check that first. You can also try this monitor with another PC to narrow down the problem.
Please post back what you find for further help.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 07, 2011 | Sony Computers & Internet
All of a sudden, the screen display went black. When we restart the computer (Windows XP), we see the initial windows logo but nothing else -- EXCEPT, pressing and holding the screen's "INPUT...
Very doubtful. Either you have a defective or corrupt display driver, or possibly a malware infection. Is that a laptop or notebook computer? If so, is there a VGA port for an external monitor? If do, try using a known good external monitor.
Apr 28, 2017 | Sony SDM-HS74P/S 17" LCD Monitor
Digital Camera HP Photosmart M517 Want to take a picture of my computer screen to send by email. Flash goes off every time and leaves a bright white light that obscures the screen. Can I disable the flash...
Press the flash button (just under the viewfinder) to cycle through the flash settings. Your choices are Auto Flash, Auto Flash with Red-eye Reduction, Flash On, Flash Off, and Night.
If you want to capture the screen image, you're better off using the computer operating system's screen-capture capability. This will give you the screen exactly as it is, without the distortions inherent in converting to an analog image and then converting it back to a digital image.
Mar 15, 2010 | HP Photosmart M517 Digital Camera
INPUT2: HD15 keeps coming up on my screen. i cant get through it. do i need to buy new input2: HD15 cable? the monitor is sony make and the hardrive is fujitsu siemens computer make
more information is needed for this question to be answered properly
im going to guss that this is your conection cable from video card to your monitor
try disconecting and reconecting the cable making shur that the cable is firmly conected at both ends
its posible that part of the tower case is preventing the full insertion of the cable into the socket
cut away 1/8 inch of the ruber shielding around the pc side of the cable so that it can fully be inserted into the conection
check that the pins on the male conection arn't bent or broken off
also run your closed hand down the cable itself checking for cracks cuts or breaks in the cable
if any problem is seen replace the cable if any pins are broken off check the femal reciver for the broken of part of the pin so as to not damage anothere cord
good luck
Feb 24, 2010 | Computers & Internet
I just got a 37 inch flat screen. I had it working with my direct TV box. My son pushed a button on the remote and now it will not connect to the direct TV. I need some help.
You will need to look for your input button on the tv or the remote and look at the back of your tv to see where your wires go!!!
You would make sure that the wires go to (input 1) are input2
Then you put your input on input1 are input2 and your wires in input1 are input2 on the back of the tv.
Feb 17, 2010 | Insignia 37" LCD Flat-Panel HDTV
I turn on the desktop and the monitor only says no input signal input2: HD15 go to power save what do i do?
Did you try to use two monitors and put this one on input two? If so, reboot in safe mode and set the settings right by going to Control Panel->Display->settings. There select the No 1 monitor and then reboot.
Oct 11, 2009 | Office Equipment & Supplies
The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
Oct 26, 2008 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Computers & Internet Logo
496 people viewed this question
David Payne
David Payne
