Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
  • 1 more comment
  • nigearnold Oct 10, 2008
    I have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
    Any idea what the problem is?
  • egordy Dec 02, 2008
    my washer dryer model wd71 displays the same error code e30 after starting it on a normal wash it fills with water then instantly goes into spin stops and displays as said code??
  • frazercowie
    frazercowie Feb 01, 2013
    i have a hotpoint w/dryer model WD71, what does the error code E30 mean which keeps coming up as it starts to fill up
  • 750 Answers
Hello john walker24
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Please remember to leave a rating!
Thank You.
Waiting for your response!
Posted on Oct 17, 2008
On inspection (remove the top lid - three screws, instructions on rear of machine) the rotation motor brushes were worn and sparking. They needed replacement! Working on that one soon...
Posted on Apr 04, 2009
  • phil_tho Apr 21, 2009
    I dismantled the 'rotation motor' ( the one that operates through a belt drive TO THE DRUM) and found the brushes worn - (One brush friction polished, one brush pitted and dull) and the motor unserviceable because of this! I have removed the brush-holders and am presently looking for replacement brushes. The brush-holder assemblies are plastic, with brass-holders for the brushes.I am presently sourcing replacements. Stay Tuned....
F&P GW709 top loader filling water intervally
Error Code 105
105. (01101001) Phase 2 to 5 - Comms. Error Time-out
These faults are reported when the Display module detects an error in the communications
between the Display module and the Motor Controller.
NB. If the product is an IW, check that the motor controller is not 426520. If it is replace with a
compatible part. This is incompatible and will give a fault code 105 at the start of agitate. Not
before! If it is a 426520 replace motor controller with a compatible part.
Primary Source - Display module
Action - Replace Display module.
Secondary Source - Motor Controller
Action - Replace Motor Controller
Tertiary Source - Rotor Position Sensor (Phase 5 Only)
Action - Replace Rotor Position Sensor. If the new Rotor Position Sensor corrects the fault refit
the original display module and motor controller.
Aug 02, 2013 | Fisher and Paykel Fisher & Paykel Washer
Hotpoint Ultima WF860T
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Zanussi zfw 1631 w skipping through programmes straight onto drain from wash. has been coming up with an error code e30
I'm going to take a stab at the filter on the empty pump being blocked.
I have tried to find an error code that matches for you and loads of forums talk about a possible blocked pump filter (Though I have seen a motor fault mentioned too!).
Try checking the filter out, it's the biggest cause of questions being posted on this site for washing machines
Jun 29, 2011 | Zanussi Washing Machines
Getting an error messsage on my hotpoint ultima wm72 code is e30
It means motor problem, see below
It could be as simple as the motor requiring new brushes which can be bought quite cheaply on ebay or as complicated as the pcb motor controller being faulty. The brushes are however easily checked
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.Read on....
Hotpoint Error Messages and Error Codes
The following are an explanation of specific error codes that may appear if there is a problem with your Hotpoint washing machine, tumble dryer, dishwasher, fridge or freezer. In most cases it is recommended to book a service engineer to rectify this fault but there are certain things that you can do to minimise any inconvenience or even avoid an unnecessary engineer visit.
Don't forget, should our advice fail to solve your issue then you can book a Hotpoint appliance repair . Alternatively phone us on 08448 224 224 to book your washing machine repair.
If an explanation of an error code on your Hotpoint appliance is not shown please contact us for an explanation
Hotpoint Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred. Book a washing machine repair
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a washing machine repair
  • F17 - Door not closed properly. Close door firmly at the 3 o'clock position.
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing. Book a washing machine repair.
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
  • F40 - Water below protection level during a heat step. Book a washing machine repair.
  • F41 - Water level detect sequence incorrect. Book a washing machine repair.
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a washing machine repair to re-programme your product.
Feb 26, 2011 | Hotpoint Washing Machines
E30 error message what does it mean, Cheers, Dave
E30 can be a faulty pressure switch,Heating element earth fault or the main P.C.B.(Programmer).Does the machine fill with water then empty.
Most common fault is the heating element,once this is replaced it should cure the fault.
May 03, 2010 | Zanussi ZWF1430W Front Load Washer
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
Hotpoint Ultima WD71 - floods on drying programme
you may have a hose loose or holed at the inside rear of the machine.
Jan 04, 2009 | Hotpoint Ultima WD72 Front Load...
I have a c1 error on an AEG oko favorite 50700 What dies this error mean
I don't understand why replies talk about the C2 and C3 errors... The problem is C1! I have the C1 error. I start a programme, it does the draining cycle to check empty then starts filling. MI can hear water entering but it sounds slow at a low flow rate. If I leave it going, eventually the programme stops and the error is displayed: C1 Opening and closing the door allows the programme to continue. I get the error after the various stages of the programme, when it is filling for the next wash or rinse. So it's 4 or 5 times I think during the programme. Now, if I help the filling... When the appliance is filling, I open the door, and poor in a kettle or two of water, then the error does not happen (the fill is within the time expected by the appliance?) So I am thinking one of two things is wrong: 1) I have a flow rate problem BEFORE the water connection to the appliance. E.g. It is blocked somehow. 2) There is something which opens/closes the "tap" within the machine which is causing the flow rate to be low and it does not fill quickly due to that. No idea which of these two, but I did disconnect the hose of the supply and check that water flows quickly from it into a bucket, so I am thinking there is something inside the machine which "opens the tap" and it's not doing a good job of it. Anyone got a clue?
Dec 18, 2008 | AEG 24 in. Favorit 50730W Free-standing...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
1,258 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
